额定值和特性/Rating and characteristic
额定温度:-40~+85℃
电容量范围:0.01~10.0 μF
标称电容量偏差:±5%,±10%,±20%
额定电压:DC100V 250V 400V 630V
绝缘电阻:> 33,000MΩ(C≤0.33 μF)
> 10,000M Ω*μF(C>0.33μF)AT 25℃
损耗角正切:0.08% MAX AT lKHz25℃
Rated temperature:-40 ~ +85℃
Capacitance range:0.01 ~ 10.0μF
Capacitance tolerances: + 5%,+ 10%,+ 20%
Rated voltage: DC 50V/63V 100V 250V 400V 630V
Insulation resistance: > 33,OOOM Q (Cs0.33 u F)
> 10,000M Q * μF(C > 0.33 μF)AT 25℃
Dissipation factor:0.08% MAX AT 1KHz25℃
特点/Features
无电感结构
自愈性强
高容量值
Non-inductive construction
Self-healing property
High capacitance value
此产品关键字:
分频电容、轴向电容
