¼¼ÊõÒªÇó/Specifications
ÒýÓñê×¼ Reference Standard
GB 7332(EC60384-2), CECC30401-009,DIN44112,ITT005 10101-QS
ÆøºòÀà±ð Climatic Category
55/100/56
¶î¶¨µçѹ Rated Voltage
63V¡¢100V¡¢160V¡¢250V¡¢400¡¢630V
µçÈÝÁ¿·¶Î§ Capacitance range
0.0010μF to 2.2μF
µçÈÝÁ¿Æ«²î Capacitance Tolerance
±5%(J), ±10%(K)£¬±20%(M)
×Ü×ÔÉíµç¸Ð Total Self-inductance
≈8nH(P=7.5), 9nH(P=10.0), 10nH(P=15.0)
*Òý³öÏß³¤¶È leads length£º¡«2mm
Ä͵çѹ Voltage proof
1.6UR (5S)
ËðºÄ½ÇÕýÇÐ Dissipation factor
²âÊÔÆµÂÊ£¨Frequency£©
CR ≤0.1μF
CR £¾0.1μ
1KHz
≤1.0%
≤1.0%
10KHz
≤1.5%
≤1.5%
1 KHz
≤3.0%
≤1.5%
¾øÔµµç×è Insulation resistance
UR£¾100V
≥30,000MΩ£¬CR≤0.33μF
≥10,000S£¬ CR£¾0.33μ (20¡æ,100V,1min)
UR≥00V
≥15,000MΩ£¬CR≤0.33μF
≥5,000S£¬ CR£¾0.33μ (20¡æ,10V,1min)
¿É¿¿ÐÔ(DIN 40040)/Reliability(DIN 40040):
ʹÓÃÌõ¼þ£ºÎ¶È(40¡æ)£¬µçѹ( 0.5×UR)
ʧЧÂÊ≤5Fit(1FIT=1×10-9ʧЧÊý/Ôª¼þ×Сʱ)
ʧ½»ÅоÝ( DIN 44122)£º¶Ì·»ò¿ªÂ·£»µçÈÝÁ¿±ä»¯(¡÷C/C±10%)£ºËðºÄ½ÇÕýÇб仯£¨¡÷tgδ >2׶ֵ£©
¾øÔµµç×裨< 0.005׶ֵ£©
Application Condition:Temperaturet£¨40¡æ ) ,Voltage ( 0.5 x UR£©
Failure Rate:≤5Fit
Failure Criteria(DIN 44122):Short or open circuit;Capacitance change ( ¡÷C/C±10%)£»
Disspation factor change ( ¡÷tgδ> 2 x initial limit) ;
Insulation resistance£¨0.005 x initial limit£©
´Ë²úÆ·¹Ø¼ü×Ö£ºÐ£ÕýµçÈÝ
»ªÔ£µçÈÝ-¸ßÆ·ÖʽðÊô»¯±¡Ä¤µçÈÝ×¨ÒµÖÆÔìÉÌ
