Type
MINI-ITX
Platform
Intel ATOM Processor
Mode
TIGD-I
System Specification
CPU
Intel atom Dual Core D525 1.8G Processor
System Memory
DDR3 800MHZ SO-DIMM X2 Solt Max 4GB
Chipset
D525+NM10
BIOS Flash
AMI 8Mbit Falsh
Super IO Chipset
ITE 8718F
Display Specification
LCD Interface
Single-Channel 18 bit LVDS up to1366x768
Graphic Resoultion
VGA Mode: up to 1920*1080
Graphic Controller
DX9
Multiple Display
VGA+LVDS
Audio
Codec
Realtek ALC655 HD AUDIO Codec
Audio Interface
line-in,line-out,Mic in
Ethernet
LAN
Dual Broadcom Gbe Controller
Ethernet Interface
2xRealtek RTL8111E
I/O Ports Specification
Rear I/O
2XRJ-45
2XPS/2(KB/MS)
1XRS-232
1XLPT
4XUSB
1XVGA
1XAUDIO JACK
Internal I/O
7X-RS-232 by pin-header
COM7/8 change to TTL
1xLVDS by 2X10pin-header£¨single channel for 18/24BIT£©
4xUSB by pin-header
2xSATA II
1XDigital I/O 2X2-pin connector(DIO)
Expension Slot
1XMini PCIe
2X SO-DIMM
1XPCI
1XPCIe(x1)slot
Mechanical and Environment
Width
170
Depth
170
Operating Temperature
0 deg.C to 60 deg.C
Storage Temperature
10-95%rh @400C non-Condensing
OS Support
Windows 7,Windows XP
