型号Model
Unit
YT-85T-C
射出系统
螺杆直径Screw Diameter
mm
36
42
射出压力Injection pressure
kg/cm²
1842
1599
理论射出容量Theorfical Shot Volume
cm³
142
215
射出量(PS)Max.shot Weight(PS)
g/0z
132/4.6
194/7
射出率Injection Rate
cm²/see
120
83
螺杆行程Screw stroke
mm
140
螺杆转速Screw Speed Max
rpm
0-300
射嘴接触力Nonzzle Contactforce
tf
5.5
射嘴行程Nonzzle Retraction Stroke
mm
210
温度控制段数Number of temperature Contorl
3+1
锁模系统
锁模力Clampieng Force
tf
85
模板尺寸Plateu Size
mm
680*570
模柱间距Disitance Betqeen Tie Bare
mm
500*350
最小模厚Min.Mold Height
mm
230/330
开模行程Oprening Stroke
mm
250
最大开模距Max.Mold Height
mm
480/580
顶出力量Ejector Stroke
tf
2.7
顶出行程Ejector Strke
mn
油压电力系统
最大液压压力Max.Hydaulic Pressure
kg/cm²
140
泵浦叶出量Pump Output
l/min
65
作动油量Oil Resservoir Capacity
l
180
冷却水用量Cooling Water Cousumption
l
800-1000
马达电力Pump Motor Power
kw
11(15HP)
电热容量Borrl Heating Power
kw
5.6
总用电量Total Weight
kw
16.6
其它
机器总重Machine Weight
kg
5000
机器外型尺寸Machine Dimensious(LsWsH)
m
2.5*1.5*3.5
装箱重量Shipping Weight
kg
5500
装箱尺寸Shipping Dimensious(LsWsH)
m
2.8*1.8*3.0
