Öлª¹¤¿ØÍø ¡ú ¹¤¿Ø²úÆ· ¡ú ½ø¿ÚºãλìË®·§Æ·ÅÆ£¬²ÎÊý
²úÆ·Ãû³Æ£º ½ø¿ÚºãλìË®·§Æ·ÅÆ£¬²ÎÊý
ÐÍ ºÅ£º LIPH
½ø¿ÚºãλìË®·§
µÂ¹úÀׯÕLIPºãλìË®·§ÓÉÖйúÉîÛÚÅɿ˷§ÃÅÓÐÏÞ¹«Ë¾×Ü´úÀí
µÂ¹úÀׯÕLIP·§ÃÅÑϸñ°´ÕÕISO9001ÖÊÁ¿¹ÜÀíÌåϵ½øÐÐÉú²ú¹ý³Ì¿ØÖÆ£¬±£Ö¤·§ÃŵÄÿ¸ö×é¼þ¶¼´ïµ½ÒªÇ󣬲¢½øÐÐÑϸñµÄ³ÉÆ·²âÊÔ£¬´Ó¶ø±£Ö¤µ½Óû§µÄÿ¼þ·§ÃŲúÆ·¶¼ÊǺϸñ²úÆ·¡£
Germany LIP valve rep in strict accordance with the ISO9001 quality management system and production process control, to ensure that each component of the valve can meet the requirements, and strict product testing, to ensure that every user to valve products are qualified products.
ÐͺţºLIP
µÂ¹úÀ×ÆÕºãλìË®·§ÊÇרΪÈÈˮϵͳÑÐÖÆµÄÅäÌײúÆ·£¬¹ã·ºÓ¦ÓÃÓÚÌ«ÑôÄÜÈÈË®Æ÷¡¢¼¯ÖÐÈÈˮϵͳ¼°µçÈÈË®Æ÷µÈ¡£
Óû§¿ÉÒÔ¸ù¾ÝÐèÒª×ÔÐе÷½ÚÀäÈÈË®»ìˮζȣ¬ËùÐèζȿÉÒÔѸËÙ´ïµ½²¢ÇÒÎȶ¨ÏÂÀ´£¬±£Ö¤³öˮζȺ㶨£¬ÇÒ²»ÊÜˮΡ¢Á÷Á¿¡¢Ë®Ñ¹±ä»¯µÄÓ°Ï죬½â¾öʹÓÃÈÈˮʱˮκöÀäºöÈȵÄÎÊÌ⣬Àäˮһµ©Öжϣ¬ÈÈË®×Ô¶¯Í£Ö¹£»ÈÈˮһµ©Öжϣ¬ÀäˮҲ»á×Ô¶¯¹Ø±Õ£¬·ÀÌÌÉË¡¢·ÀÀ伤¡£¿ÉÔÚ¼ÒÍ¥Éú»îÈÈË®¡¢·¹µê¡¢Ò½Ôº¡¢Ñ§Ð£µÈÒªÇóÌṩÎȶ¨¹©Ë®Î¶ȵÄÖС¢Ð¡ÐÍÉú»îÈÈˮϵͳÖÐʹÓᣠ
Germany leipold thermostatic mixing valve is designed for the hot water system and auxiliary products, widely used in solar water heater, central hot water system and the electric water heater.
The user can adjust the mixing of hot and cold water temperature according to the need, the required temperature can be achieved quickly and stable, ensure the water temperature constant, and is not affected by water temperature, flow, pressure,
temperature of the solution to the problem sometimes hot and sometimes cold with hot water, cold water in the hot water once broken, automatic stop; hot water once interrupted, cold water will automatically shut down, anti scald, prevent cold shock. In the domestic hot water, hotel, hospital, school and other requirements to provide a stable supply water temperature of the medium and small living hot water system in the.
ÔÚºãλìË®·§µÄ»ìË®³ö¿Ú´¦£¬×°ÅäÓÐÈÈÃô¸ÐÎÂ×é¼þ£¬Ë®Î±仯ʹÈÈÃô×é¼þÅòÕÍ»òÊÕËõ¿ØÖÆ·§ÄÚ·§Ð¾Òƶ¯£¬·â¶Â»òÕß¿ªÆôÀä¡¢ÈÈË®µÄ½øË®¿Ú¡£µ±Î¶ȵ÷½ÚÐýÅ¥É趨ijһζȺ󣬻ìË®·§Í¨¹ýµ÷½Ú½øÈë³öË®¿ÚµÄÀäÈÈË®±ÈÀý£¬Ê¹³öˮζÈʼÖÕ±£³Öºã¶¨¡£²»»áÊÜÈÈˮζȵĽµµÍ¡¢ÓÃË®Á¿µÄÔö¼õ»òˮѹ±ä»¯µÄÓ°Ïì¡£
In the mixed water outlet thermostatic mixing valve, fitted with the thermosensitive temperature sensing component, the component temperature thermal expansion or contraction control mobile spool valve, inlet seal or open the cold, hot water. When the temperature control knob to set a temperature, hot and cold water mixing valve through proportional control into the outlet, the outlet temperature is always constant. Not affected by reducing the temperature of hot water, with water or water pressure changes.
½ø¿ÚºãλìË®·§ÔÚÌ«ÑôÄÜϵͳÉϵÄÓ¦ÓÃApplication of import thermostatic valve in the solar system.
Ì«ÑôÄÜÈÈË®Æ÷¹«Ë¾ÎªÁËʹÓû§¶¬ÌìÔçÉÏÄÜÏ´ÉÏÈÈË®Ô裬¶¼´ó´óµØÌá¸ßÁ˼¯ÈÈÄÜÁ¦£¡µ«¶¬¼¾µÄÈÈÁ¿´ïµ½ÁË“±ê×¼”£¬Ïᄀ¢Çï¼¾µÄÈÈÁ¿¾Í»á¹ýÊ££¬³¬¸ßÎÂÈÈË®Êä³öµÄÏÖÏó¾Í²»¿É±ÜÃ⣡Ôì³ÉÏû·ÑÕßʹÓò»µ±¶øÒý·¢µÄÌÌÉ˰¸ÀýÒ²Âżû²»ÏÊ¡£Òź¶µÄÊÇûÓг§¼ÒÈ¥¿¼ÂÇÌ«ÑôÄÜÈÈË®Æ÷·ÀḬ̀²È«µÄÎÊÌ⣬ÔÚÈÕÕÕ³ä·Ö»ò¶àÌì²»ÓÃÇé¿öÏ£¬Âäˮʽ̫ÑôÄÜÈÈË®Æ÷µÄ×î¸ßÊä³öˮοÉÒÔ´ïµ½100¡æ£¬³ÐѹʽÉõÖÁ»á¸ü¸ß£¬Òò´Ë¶ÔÑ¡ÓõÄÈÈË®¹ÜÒ²±ØÐëÊÇÄ͸ßεģ¬ÕâÑù²»µ«Ìá¸ßÁ˳ɱ¾£¬»¹ÁôÏÂÁËÒþ»¼¡£ÒªÊÇÓ¦ÓÃÁ˺ãλìË®·§ÎÊÌâ¾ÍÓ­Èжø½â£¬²»Óÿ¼ÂÇÈÈË®ÊÇ80¡æ»¹ÊÇ100¡æ£¬Ö»Òª½«ºãη§É趨Ϊ40¡æ£¬ÄÇô¾Í»áµÃµ½40¡æµÄ³öË®¡£
Solar water heater company in order to winter morning to wash the hot bath, can greatly improve the heat collecting capacity! But the winter heat to achieve a "standard", the excess heat in summer and autumn will, ultra high temperature hot water output phenomenon is inevitable! Due to improper use of consumers caused by burn cases are not uncommon. Unfortunately there is no manufacturers to consider the safety of the solar water heater hot issues in full sunshine or more days without conditions,
the highest output water temperature water type solar water heater can reach 100 DEG C and the pressure will be even greater, so the choice of hot water pipe must also be resistant to high temperature, which not only improves the the cost, but also left a hidden danger. If the application of thermostatic mixing valve problem is solved, regardless of water is 80 degrees or 100 degrees, as long as the thermostatic valve set at 40 C, 40 C would.
ÖÆÔì±ê×¼£ºÃÀ±ê¡¢¹ú±ê¡¢µÂ±ê
²úÆ·²úµØ£ºµÂ¹ú
²úÆ·Æ·ÅÆ£ºµÂ¹úÀׯա¶LIP¡·
¹«Ë¾Ãû³Æ£º ÉîÛÚÅɿ˹¤Òµ·§ÃÅÓÐÏÞ¹«Ë¾
µç »°£º 0755 81713669 / ÁÖÉú
ÊÖ»ú£º 13827443669
µØ Ö·£º Áú»ªÐÂÇø¶Õ±³¹¤ÒµÇø18ºÅ
ÓÊ ±à£º 518109
Ö÷ Ò³£º http://www.gdparker.com
  • ½ø¿Ú¸ßѹËÄͨÇò·§£¨Æ·ÅÆ£©
  • ½ø¿ÚÕôÆûµç¶¯Çò·§£¨Æ·ÅÆ£¬²ÎÊý£©
  • ½ø¿ÚÆø¶¯Ð¶»ÒÇò·§£¨Æ·ÅÆ£©
  • ½ø¿ÚÆø¶¯³¬±¡ÐÍÇò·§£¨Æ·ÅÆ£©
  • ½ø¿Ú·À±¬µç¶¯Çò·§(½ø¿Úµç¶¯Çò·§£©
  • ½ø¿Ú¸ßѹֱ¶¯Ê½µç´Å·§
  • ½ø¿Ú¸ßÕ³¶Èµç´Å·§£¨Í¼Æ¬£©
  • ½ø¿ÚºãλìË®·§Æ·ÅÆ£¬²ÎÊý
  • ½ø¿Ú°²È«ÒçÁ÷·§
  • ½ø¿ÚÎÀÉú¼¶°²È«·§½ø¿ÚÖÆÒ©°²È«·§
