Î÷ÃÅ×Ó6ES7 972-0AB01-0XA0 12M PROFIBUS Õï¶ÏÖÐ¼ÌÆ÷ ÎÒ¹«Ë¾³¤ÆÚÏúÊÛÎ÷ÃÅ×Ó¹¤¿ØÏµÁвúÆ· ³Ðŵ£ºÖʱ£Ò»Äê È«ÐÂÔ×°
»¶ÓÀ´µç×Éѯ¶©¹º
Design
¾ßÓÐ IP 20 ·À»¤µÈ¼¶µÄÍâ¿Ç
°²×°ÔÚ S7-300® ×éºÏ¹ìµÀ»ò DIN ¹ìµÀÉÏ
LED ÓÃÓÚÏÔʾ 24 V DC¡¢×ÜÏ߻Óëÿ¶ÎµçÀµĹÊÕÏ
½ÓÏߺÐÓÃÓÚ 24 V DC £¨Íⲿ£© µçÔ´µçѹ
Sub-D ÐÍ 9 ½ÅÁ¬½ÓÆ÷ÓÃÓÚÁ¬½Óµ½ PROFIBUS
ÀûÓà FastConnect ¾øÔµÎ»ÒÆ·¨Á¬½Ó 3 ¶Î×ÜÏß
Õï¶ÏÖÐ¼ÌÆ÷×÷Ϊһ¸ö DP ±ê×¼ PROFIBUS ´ÓÕ¾¼¯³ÉÔÚ×ÜÏßϵͳÖУ¬ ËüÖ§³Ö£º
Ö»ÓÐÔÊÐíµÄ×ÜÏßÁ¬½ÓÆ÷²ÅÄÜÁ¬½Óµ½¾ßÓÐÕï¶ÏÄÜÁ¦µÄ¶ÎÉÏ £¨²Î¼û¶©»õÊý¾Ý / ¸½¼þ£©
±ØÐë×ñÊØ 12 Mbaud ÍøÂçµÄ°²×°Ö¸ÄÏ
Functions
ÔËÐÐģʽ
ÖÐ¼ÌÆ÷¹¦ÄÜ
Õï¶ÏÖÐ¼ÌÆ÷ÊÇ×÷Ϊһ¸ö³£¹æµÄ RS 485 ÖÐ¼ÌÆ÷¼¯³ÉÔÚ×ÜÏßϵͳÖе쬵«Ëü¾ßÓÐÒ»¸öµ¥¶ÀµÄ PROFIBUS DP µØÖ·£º
Ôö¼ÓµÄÕ¾µãÊýÁ¿(×î¶à127¸ö)£¬ÔÚ×ÜÏßϵͳÖÐÀ©Õ¹
ÔÚÕñ·ùºÍʱ¼äÄÚÖØÐÂÉú³ÉÐźÅ
Á¬½Ó¶ÎµÄ¹â¸ôÀë
ͨ¹ý STEP® 7¡¢COM PROFIBUS »òÕß GSD Îļþ½øÐÐ×é̬¡£
Óë FW °æ±¾V2.0.0£¬²¢¾ßÓÐÒÔϸ½¼Ó¹¦ÄÜ£º
Õï¶Ï¹¦ÄÜ
ͨ¹ý STEP 7 »òÕß COM PROFIBUS ³õʼ»¯£¬Õï¶ÏÖÐ¼ÌÆ÷¾ö¶¨ÁËÁ¬½Ó¶ÎµÄÍØÆË½á¹¹²¢½«Ëü´æ´¢ÔÚÄÚ²¿Õï¶Ï´æ´¢Æ÷ÖС£
ÔÚ·¢Éú¹ÊÕÏʱ£¬ÖÐ¼ÌÆ÷×Ô¶¯½«°üº¬ÏÂÁÐϸ½ÚµÄÒ»¸ö±ê×¼Õï¶ÏÏûÏ¢´«µÝ¸ø×ÜÏßÖ÷Õ¾£º
Äܹ»Õï¶ÏÏÂÁдíÎó£º
Ò²¿ÉÒÔʶ±ðÁãÐÇ´íÎó
´íÎó±¨ÎÄÔÚ STEP 7 ºÍ COM PROFIBUS ÖÐÒÔͼÐη½Ê½ÏÔʾ¡£ ËüÃÇÍêÈ«¼¯³Éµ½ÁË SIMATIC ϵͳÕï¶ÏÖÐ (È磬×ÜÌåÕï¶Ï£¬“±¨¸æÏµÍ³´íÎ󔹦ÄÜ)¡£
STEP 7µÄÏÔʾÖаüÀ¨Ò»¸ö¹ÊÕÏÅųý´ëÊ©µÄ°ïÖúÎı¾¡£ ±àд¸Ã°ïÖúÎı¾£¬ÎÞÐèÌØ¶¨µÄPROFIBUSרÃÅ֪ʶ£¬Òò´Ë£¬¿É½«´íÎóѸËٵؾֲ¿»¯ºÍÅųý¡£
ÍøÂçÍØÆË½á¹¹ºÍͳ¼ÆÏÔʾ
ͨ¹ýStep 7 V 5.2£¬¿É»ñµÃÍØÆË½á¹¹Í¼Ðλ¯ÏÔʾ£¬ÆäÖÐÏÔʾÁËÕ¾ºÍÏß·³¤¶È¡£
»¹¿ÉÒÔͳ¼ÆÊý¾ÝµÄÐÎʽÏÔʾ×ÜÏßϵͳµÄÖÊÁ¿¡£
´òÓ¡¹¦ÄÜ
STEP 7 V53.3, SP 3 °üÀ¨¸Ä½øµÄ´òÓ¡¹¦ÄÜ¡£ »¹¿Éͨ¹ýÏÔʾÆÁ½øÐÐÔ¤ÀÀºÍÓÅ»¯´òÓ¡½á¹û¡£ ÀýÈ磬¿ÉÒþ²ØÄ³Ð©Ìض¨Ï¸½Ú£¬Ò²¿ÉÔÚDIN A4 »òDIN A3 ÕÅÉÏ´òÓ¡³öÍØÆË½á¹¹µÄ×ÜÀÀͼ¡£
×é̬
Õï¶ÏÖÐ¼ÌÆ÷°´ÈçÏ·½Ê½×é̬£º
STEP 7 V5.1, °üÀ¨ Service Pack 2
COM PROFIBUS V5.1, °üÀ¨ Service Pack 2
µÚÈý·½¹¤¾ß£º ͨ¹ý GSD Îļþ
Èç¹ûʹÓõÚÈý·½Ö÷Õ¾£¬ÓпÉÄÜͨ¹ý COM PROFIBUS À´¾ö¶¨ÍØÆË½á¹¹¡£ µÚÈý·½×é̬¹¤¾ß²»Äܾö¶¨ÍØÆË½á¹¹¡£ È»¶ø£¬Èç¹ûÒ»µ©Ê¹Óà COM PROFIBUS È·¶¨ÁËÍØÆË½á¹¹£¬½Ó×ŵÚÈý·½×é̬¹¤¾ß½«»áÔÚ³ö´íµÄλÖÃÏÔʾ³öÐÅÏ¢¡£
Technical Specifications
6ES7 972-0AB01-0XA0
Supply voltage
24 V DC
Yes
permissible range, lower limit (DC)
20.4 V
permissible range, upper limit (DC)
28.8 V
Interfaces
Bus cables
FastConnect insulation displacement, 10 clamping cycles possible
PROFIBUS DP
12 Mbit/s; 9.6 kbit/s to 12 Mbit/s
Degree and class of protection
Yes
Ambient conditions
Operating temperature
0 °C
60 °C
Storage/transport temperature
-40 °C
70 °C
Relative humidity
95 %; at 25 °C
Connection method
Power supply
Terminal block
Dimensions
Width
80 mm
Height
125 mm
Depth
67.5 mm
Weights
Weight, approx.
300 g
