产品名称:
美国BANNER光电传感器Q12AB6FF15
型 号:
Q12AB6FF15
价 格:
0.00
品 牌:
传感波长:640
最大传感范围:15mm
电源电压:10-30 V dc
输出方式:NPN&PNP
输出响应时间:0.7ms
重复性:175µs
连接:2m 电缆
保护等级:IP67
温度范围:-20℃...+55℃
最大湿度:95% @ 50°C
外表材质:热塑塑料
镜头材料:聚碳酸酯
Sensing Mode (General)
Proximity
Sensing Mode (Specific)
Background Suppression (Fixed)
Sensing Beam Wavelength
640
Max Sensing Range [mm]
15
Supply Voltage
10-30 V dc
Output Type
Bipolar (NPN & PNP)
Operation
Light Operate
Output response time [ms]
0.7
Delay at Power-up [ms]
120
Repeatability (µs)
175
Connection
2 m Cable
Number of Pins
3
IP Rating
IP67
Min Op. Temperature [°C]
-20
Max Op. Temperature [°C]
55
Max Op. Relative Humidity [%]
95% @ 50℃
Basic Housing Material
Thermoplastic
Housing Style
Rectangular
Lens Material
Polycarbonate
