BANNER QS18EN6CV45抗干扰光电传感器
Sensing Mode (General)
Proximity
Sensing Mode (Specific)
Convergent
Sensing Beam
Visible Red LED
Max Sensing Range [mm]
43
Supply Voltage
10-30 V dc
Output Type
NPN
Operation
Light/Dark Operate
Output response time [ms]
0.6
Delay at Power-up [ms]
100
Repeatability (μs)
75
Connection
2 m Cable
Number of Pins
4
IP Rating
IP67
NEMA Rating
NEMA 6
Min Op. Temperature [℃]
-20
Max Op. Temperature [℃]
70
Max Op. Relative Humidity [%]
95% @ 50℃
Basic Housing Material
Thermoplastic
Housing Style
Rectangular with M18 Barrel
Lens Material
PMMA
Adjustments
Teach Button
Barrel Diameter [mm]
18
