免费注册 登录 | 广告服务 | 客服中心
中华工控网 → 工控产品 → 美国BANNER 对射式光电开关QS30EVD
产品名称: 美国BANNER 对射式光电开关QS30EVD
型 号: QS30EVD
价 格: 0.00
品 牌:
Sensing Beam
660 nm visible red
Supply Voltage
10 to 30V dc (10% max. ripple) @ 25 mA max current, exclusive of load
Supply Protection Circuitry
Protected against reverse polarity, over voltage, and transient voltages
Delay at Power-Up
250 ms; outputs do not conduct during this time
Output Configuration
Bipolar: 1 current sourcing (PNP) and 1 current sinking (NPN)
Output Ratings
150 mA maximum load (derate ~ 1 mA/°C above 25°C)
OFF-state leakage current: < 50 μA at 30V dc
ON-state saturation voltage:
NPN: < 200 mV @ 10 mA; < 1V @ 150 mA
PNP: < 1.25V @ 10 mA; < 2V @ 150 mA
Output Protection
Protected against output short-circuit, continuous overload, transient over-voltages, and false pulse on power up
Output Response Time
High-Speed Mode: 300 microseconds
Normal Mode: 1.8 ms
Repeatability
High-Speed Mode: 100 microseconds
Normal Mode: 150 microseconds
Adjustments
2 push buttons and remote wire
• Easy push-button configuration
• Manually adjust (+/–) cutoff (push buttons only)
• Light Operate/Dark Operate and OFF-delay configuration options (push buttons only)
• Push-button lockout (from remote wire only)
Indicators
8-segment red bargraph: Distance relative to cutoff point
Green LED: Power ON
Yellow LED: Output conducting
Construction
ABS plastic housing; acrylic lens cover
Environmental Rating
IP67, NEMA 6
Connections
5conductor 2 m (6.5') PVC cable, 9 m (30') PVC cable, or 5-pin integral Euro-style quick-disconnect fitting
公司名称: 深圳市创丰仪器仪表有限公司
电 话: 0755 29796001-806 / 钱军辉
手机: 13143436561
地 址: 深圳市宝安九区白金酒店商务大厦1001-1002室
邮 编: 518052
主 页: www.Lansea.net
  • ZCMD25施耐德限位开关组件
  • 施耐德ZCMD21限位开关零部件
  • XCM-D2516L3施耐德限位开关零部件
  • XCM-D2516L1限位开关零部件
  • Panasonic松下GD-C1双层重叠检测器
  • 全新原装松下聚焦镜FX-LE2
  • omron欧姆龙W4S1-03B可编程控制器
  • omron欧姆龙E39-R3不锈钢外壳小型光电传感器
  • OMRON欧姆龙D4E-1D10N 限位开关
  • KEYENCE基恩士光幕电源线GL-RP10P
