产品名称:
邦纳两级输出型接近式传感器QS30AF600
型 号:
QS30AF600
价 格:
0.00
品 牌:
Sensing Mode (General)
Proximity
Sensing Mode (Specific)
Background Suppression (Adjustable)
Sensing Beam Wavelength
660
Max Sensing Range [mm]
600
Supply Voltage
10-30 Vdc
Output Type
Bipolar (NPN & PNP)
Operation
Light/Dark Operate
Output response time [ms]
5
Delay at Power-up [ms]
200
Repeatability (µs)
750
Connection
2 m Cable
Number of Pins
5
IP Rating
IP67
NEMA Rating
NEMA 6
Min Op. Temperature [°C]
-20
Max Op. Temperature [°C]
60
Max Op. Relative Humidity [%]
95% @ 50°C
Basic Housing Material
Thermoplastic
Housing Style
Rectangular with M30 Barrel
Lens Material
Acrylic
Adjustments
Mechanical Screw
Barrel Diameter [mm]
30
