美国邦纳镜面反射光电开关MIAD9LVAG
Sensing Mode (General)
Retroreflective
Sensing Mode (Specific)
Polarized
Sensing Beam
Visible Red LED
Max Sensing Range [m]
2
Supply Voltage
5-15 V dc
Output Type
Constant Current
Operation
Light/Dark Operate
Output response time [ms]
5
Connection
2 m Cable
Number of Pins
IP Rating
IP67
NEMA Rating
NEMA 1, 2, 3, 3S, 4, 4X, 6, 12, 13
Min Op. Temperature [℃]
-40
Max Op. Temperature [℃]
70
Max Op. Relative Humidity [%]
90% @ 50℃
Basic Housing Material
Thermoplastic
Housing Style
Rectangular with M18 Barrel
Lens Material
Acrylic
Adjustments
Potentiometer
Barrel Diameter [mm]
18
公司简介 产品目录 供应信息
