SICK光电接近传感器WTB250-2R1541
特征:
检测原理/Sensor/detection principle:Photoelectric proximity sensor, Background suppression
外壳形状/Housing design (light emission):Rectangular
最大检测距离/Sensing range max.:150 mm ... 500 mm
检测距离/Sensing range:150 mm ... 500 mm
技术参数/Mechanics/electronics
电源电压/Supply voltage:24 V AC/DC ... 240 V AC/DC, 24 V DC ... 240 V DC
能量功耗/Power consumption:≤ 5 VA
输出类型/Output type:Relay, electrically isolated
输出功能/Output function:Change-over contacts
开关模式/Switching mode:Light switching
开关电压/Switching current (switching voltage):3 A (240 V AC), 3 A (30 V DC)
响应时间/Response time:≤ 15 ms
开关频率/Switching frequency:33 Hz
连接方式/Connection type:Cable, 5-wire, 2 m
电缆材料/Cable material:PVC
导线截面/Conductor cross-section:0.76mm2
电缆直径/Cable diameter:Ø 6.4 mm
电路保护/Circuit protection:A, C
电压等级/Overvoltage category:2
光学材料/Optics material:PMMA
物品提供/Items supplied:BEF-W250 mounting bracket
使用类别/Usage category:AC-15, DC-13, According to EN 60947-1
电磁兼容性/EMC:EN 60947-5-2
工作环境温度/Ambient operating temperature:-25 °C ... +55 °C
储存温度/Ambient storage temperature:-40 °C ... +70 °C
UL File No.:NRKH2.E300503 & NRKH8.E300503
外壳材质/Housing material:ABS, Plastic
