SICK 德国WLL190T-2N432光纤传感器
外形尺寸/Dimensions (W x H x D):10.5 mm x 34.8 mm x 76.5 mm
最大检测范围Sensing range max.:0 m ... 4 m, through-beam system 1)2)
检测距离/Sensing range:0 m ... 2 m, through-beam system, 0 mm ... 480 mm, proximity system 3)4) 5)
光源/Light source:LED 6)
光类型/Type of light:Visible red light
波长/Wave length:650 nm
敏感度调节/Sensitivity adjustment:Teach-in button
cable,+/- increment button, manual
工作距离调整/Adjustment of operating distance:Cable, +/- increment button, manual, Teach-in button
时间类型/Time type:Without time delay time delay off switch on delay one shot
延迟时间/Delay time:Programmable: 0 ... 9,999 ms
传感器的原理/Sensor/detection principle:Fiber-optic photoelectric sensor光纤光电传感器
分散角度/Fiber-optic photoelectric sensor:Ca. 65 °
技术参数/Mechanics/electronics
外壳防护等级/Enclosure rating:IP 66 1)
电源电压/Supply voltage:10 V DC ... 24 V DC 2)
Ripple/波纹:≤ 10 % 3)
输出形式/Output type:NPN, Light/dark-switching, manually selectable, open collector 4) 5)
电流最大输出/Output current Imax.:≤ 100 mA
响应时间/Response time:≤ 2 ms ≤ 60 µs ≤ 250 µs 6)
开关频率/Switching frequency:8,333 Hz 2,000 Hz 250 Hz
连接类型/Connection type:Cable, 4-wire, 2 m 7)
电缆材料/Cable material:PVC
导体横截面/Conductor cross-section:0.2 mm
保护等级/Protection class:III
电路保护/Circuit protection:A, B, C, D 8) 9) 10) 11)
工作环境/Ambient operating temperature:-25 °C ... 55 °C
环境储存温度/Ambient storage temperature:-40 °C ... 70 °C
重量/Weight:20g
