德国施克VTB180-2F32417光电传感器
外壳形状/Housing design (light emission):Cylindrical, straight(直圆柱形)
内部螺纹直径/Thread diameter (housing):M18 x 1
光学轴/Optical axis:Axial/轴向的
最大检测距离/Sensing range max.:10 mm ... 350 mm
检测距离/Sensing range:30 mm ... 200 mm
光的型式/Type of light:Visible red light/可见红光
光源/Light source:LED
波长/Wave length:632 nm
技术参数Mechanics/electronics
电源电压/Supply voltage:10 V DC ... 30 V DC
波动范围/Ripple:± 10 %
功能消耗/Power consumption:≤ 35 mA
输出形式/Output type:PNP
开关形式/Switching mode:Light switching/光电开关
最大输出电流/Output current Imax.:≤ 100 mA
响应时间/Response time:≤ 1 ms
开关频率/Switching frequency:≤ 500 Hz
连接方式/Connection type:Connector M12, 4-pin
电路保护/Circuit protection:A, B, D
保护等级/Protection class:III
重量/Weight:18g
外壳材质/Housing material:Plastic, PBT/PC
外壳防护等级/Enclosure rating:IP 67
工作环境温度/Ambient operating temperature:-25 °C ... +55 °C
储存温度/Ambient storage temperature:-40 °C ... +70 °C
