全新正品施克光电传感器VT12T-2P430
特征/Features:
外壳形状/Housing design (light emission):Cylindrical, straight
外壳尺寸/Housing length:65.5 mm
内部螺纹直径/Thread diameter (housing):M12 x 1
最大检测距离/Sensing range max.:0 mm ... 340 mm
检测距离/Sensing range:2 mm ... 300 mm
光源/Light source:LED
波长/Wave length:880 nm
技术参数Mechanics/electronics
电源电压/Supply voltage:10 V DC ... 30
波动范围Ripple:≤ 10 %
功能消耗/Power consumption:20
输出形式/Output type:PNP, Light/dark-switching, Selectable via control input C
输出最大电流/Output current Imax.:100
响应时间/Response time:≤ 1.25 ms
开关频率/Switching frequency:400
连接方式/Connection type:Connector M12, 4-pin
电路保护/Circuit protection:A, B, C, D
外壳材质/Housing material:Nickel-plated brass/PA
工作环境温度/Ambient operating temperature:-25 ... 70 °C
储存温度/Ambient storage temperature:-25 ... 70 °C
