产品名称:
法国施耐德XUB5BPANL2光电传感器
型 号:
XUB5BPANL2
价 格:
品 牌:
Main
Range of product
OsiSense XU
Series name
General purpose single mode
Electronic sensor type
Photo-electric sensor
Sensor name
XUB
Sensor design
Cylindrical M18
Detection system
Diffuse
Material
Metal
Line of sight type
Axial
Type of output signal
Discrete
Supply circuit type
DC
Wiring technique
3-wire
Discrete output type
PNP
Discrete output function
1 NO
Electrical connection
Cable
Cable length
2 m
Product specific application
Emission
Infrared diffuse
[Sn] nominal sensing distance
0.6 m diffuse
Complementary
Enclosure material
Nickel plated brass
Lens material
PMMA
Maximum sensing distance
0.8 m diffuse
Output type
Solid state
Add on output
Without
Wire insulation material
PvR
Status LED
1 LED (yellow) for output state
[Us] rated supply voltage
12...24 V DC with reverse polarity protection
Supply voltage limits
10...36 V DC
Switching capacity in mA
<= 100 mA (overload and short-circuit protection)
Switching frequency
<= 500 Hz
Voltage drop
1.5 V (closed state)
Current consumption
35 mA (no-load)
Delay first up
< 15 ms
Delay response
< 1 ms
Delay recovery
< 1 ms
Setting-up
Sensitivity adjustment
Diameter
18 mm
Length
62 mm
Environment
Product certifications
CE
CSA
UL
Ambient air temperature for operation
-25...55 °C
Ambient air temperature for storage
-40...70 °C
Vibration resistance
7 gn, amplitude = +/- 1.5 mm (f = 10...55 Hz) conforming to IEC 60068-2-6
Shock resistance
30 gn (duration = 11 ms) conforming to IEC 60068-2-27
IP degree of protection
IP65 double insulation conforming to IEC 60529
IP67 double insulation conforming to IEC 60529
