免费注册 登录 | 广告服务 | 客服中心
中华工控网 → 工控产品 → 施耐德电容式传感器XS8C40MP230
产品名称: 施耐德电容式传感器XS8C40MP230
型 号: XS8C40MP230
价 格: 0.00
品 牌:
Main
Range of product
OsiSense XS
Series name
General purpose
Sensor type
Inductive proximity sensor
Device application
Sensor name
XS8
Sensor design
Form 40 x 40 x 117
Size
117 mm
Body type
Fixed
Detector flush mounting acceptance
Non flush mountable
Material
Plastic
Enclosure material
Plastic
Type of output signal
Discrete
Wiring technique
2-wire
[Sn] nominal sensing distance
20 mm
Discrete output function
1 NO or 1 NC programmable
Output circuit type
AC/DC
Electrical connection
Screw-clamp terminals, clamping capacity: 2 x 1.5 mm²
[Us] rated supply voltage
24...210 V DC
24...240 V AC 50/60 Hz
Switching capacity in mA
5...300 mA AC
5...200 mA DC
IP degree of protection
IP67 conforming to IEC 60529
Complementary
Detection face
5 positions turret head
Front material
Plastic
Operating zone
0...16 mm
Differential travel
3...20% of Sr
Repeat accuracy
<= 3% of Sr
Status LED
1 LED yellow for output state
Supply voltage limits
20...264 V AC/DC
Residual current
<= 1.5 mA for open state 120 V
<= 0.8 mA for open state 24 V
Switching frequency
<= 50 Hz DC
<= 25 Hz AC
Voltage drop
<= 5.5 V at closed state
Delay first up
<= 120 ms
Delay response
<= 30 ms
Delay recovery
<= 20 ms
Marking
CE
Height/高
40 mm
Length/长
40 mm
Width/宽
117 mm
Environment
Product certifications/认证
CCC
CSA
UL
Ambient air temperature for operation/工作温度
-25...70 °C
公司名称: 深圳市创丰仪器仪表有限公司
电 话: 0755 29796001-806 / 钱军辉
手机: 13143436561
地 址: 深圳市宝安九区白金酒店商务大厦1001-1002室
邮 编: 518052
主 页: www.Lansea.net
  • ZCMD25施耐德限位开关组件
  • 施耐德ZCMD21限位开关零部件
  • XCM-D2516L3施耐德限位开关零部件
  • XCM-D2516L1限位开关零部件
  • Panasonic松下GD-C1双层重叠检测器
  • 全新原装松下聚焦镜FX-LE2
  • omron欧姆龙W4S1-03B可编程控制器
  • omron欧姆龙E39-R3不锈钢外壳小型光电传感器
  • OMRON欧姆龙D4E-1D10N 限位开关
  • KEYENCE基恩士光幕电源线GL-RP10P
