Öлª¹¤¿ØÍø ¡ú ¹¤¿Ø²úÆ· ¡ú ÎåÏßÊä³ö³¬Éù²¨½Ó½ü´«¸ÐÆ÷,UB1500-F42-UK-V95
²úÆ·Ãû³Æ£º ÎåÏßÊä³ö³¬Éù²¨½Ó½ü´«¸ÐÆ÷,UB1500-F42-UK-V95
ÐÍ ºÅ£º ÎåÏßÊä³ö³¬Éù²¨½Ó½ü´«¸ÐÆ÷,UB1500-F42-UK-V95
ÎåÏßÊä³ö³¬Éù²¨½Ó½ü´«¸ÐÆ÷,UB1500-F42-UK-V95,Ìæ´ú±¶¼Ó¸£½ø¿Ú´«¸ÐÆ÷
Ìæ´úÐͺţºUB1500-F42-UK-V95
ÆäËü³¬Éù²¨´«¸ÐÆ÷Ìæ´úÐͺÅÇëÁªÏµ1379-O755-137  ³Â ¹¤
Ìæ´úµÄ³¬Éù²¨´«¸ÐÆ÷ Öʱ£ÆÚ2Äê
UB120-F12P-EP-V15
    Ultrasonic sensor
Single head system, Switching point adjustment via potentiometer, Extremely narrow projection cone, Synchronization options, Series: -F12, Housing diameter: , Housing: Frame: nickel plated, die cast zinc,
Laterals: glass-fiber reinforced plastic PC, Sensing range: 15 ... 150 mm, Connection type: Connector M12 x 1 , 5-pin
UB1500-F42-UK-V95
    Ultrasonic sensor
Single head system, Relay output for high power, Extremely small unusable area, TEACH-IN, Series: -F42, Housing: PBT, Sensing range: 70 ... 1500 mm
UB1500-F42S-UK-V95
    Ultrasonic sensor
³¬Éù²¨´«¸ÐÆ÷×î³£ÓõÄģʽÊÇÂþ·´Éäģʽ¡£µ¥¸ö³¬Éù²¨´«¸ÐÆ÷¼ÈÊÇ·¢ÉäÆ÷ÓÖÊǽÓÊÕÆ÷£¬²¢ÇÒͨ³£°üº¬ÏàÓ¦µÄµç×Ó´¦ÀíÔª¼þÔÚͬһ¸öÍâ¿ÇÄÚ¡£
ΪÁ˿ɿ¿µØ¼ì²âÀ§ÄÑÄ¿±êÎ´ó¶àÊýµÄÂþ·´Éäģʽ´«¸ÐÆ÷¿ÉÒÔͨ¹ýÈí¼þ²ÎÊýÉèÖã¬×ª»»Îª·´Éä°åģʽ¡£Óеij¬Éù²¨´«¸ÐÆ÷´ÓÒ»¿ªÊ¼¾ÍÌṩÁË·´Éä°åģʽµÄ´«¸ÐÆ÷¡£
¸ßµÍµã¼ì²â³¬Éù²¨½Ó½ü¿ª¹Ø
¿ª¹ØÁ¿³¬Éù²¨´«¸ÐÆ÷
Ä£ÄâÁ¿³¬Éù²¨´«¸ÐÆ÷
Ö±½Ó¼ì²â³¬Éù²¨½Ó½ü´«¸ÐÆ÷
µçѹÊä³ö³¬Éù²¨´«¸ÐÆ÷
µçÁ÷Êä³ö³¬Éù²¨½Ó½ü¿ª¹Ø
Ë«¶Ë¿ÚÊä³ö³¬Éù²¨½Ó½ü´«¸ÐÆ÷
ËÄÏßÊä³ö³¬Éù²¨½Ó½ü´«¸ÐÆ÷
DC³¬Éù²¨½Ó½ü¿ª¹Ø
·Ç½ðÊô¼ì²â³¬Éù²¨½Ó½ü¿ª¹Ø
¿í¶È¼ì²â³¬Éù²¨´«¸ÐÆ÷
´©Í¸¼ì²â³¬Éù²¨½Ó½ü¿ª¹Ø´«¸ÐÆ÷
³¬³¤¾àÀë¼ì²â³¬Éù²¨½Ó½ü¿ª¹Ø´«¸ÐÆ÷
¼ì²âÖ½Õźñ¶È³¬Éù²¨½Ó½ü¿ª¹Ø´«¸ÐÆ÷
¶ÔÉä¼ì²â³¬Éù²¨½Ó½ü¿ª¹Ø´«¸ÐÆ÷
90¶È¼ì²â³¬Éù²¨Ì½Í·½Ó½ü¿ª¹Ø´«¸ÐÆ÷
¸ß¾«¶È³¬Éù²¨½Ó½ü¿ª¹Ø
¸ßƵÂʳ¬Éù²¨¼ì²â´«¸ÐÆ÷
¶àµã¼ì²â³¬Éù²¨´«¸ÐÆ÷
×Ô¶¯¶¨Î»¼ì²â³¬Éù²¨´«¸ÐÆ÷
Æû³µÅÄ볬Éù²¨´«¸ÐÆ÷
ÓÐÎÞ¸ßËÙ¼ì²â³¬Éù²¨´«¸ÐÆ÷
¾«ÃܵçµñÓýӽü¿ª¹Ø
¾«ÃܵçµñÓó¬Éù²¨´«¸ÐÆ÷
¾«ÃܵçµñÓùâµç¿ª¹Ø
³¬Éù²¨½Ó½ü´«¸ÐÆ÷,UB120-12GM-I-V1,Ìæ´ú¼Ó¸£½ø¿Ú´«¸ÐÆ÷
¸ßµÍµã¼ì²â³¬Éù²¨½Ó½ü¿ª¹Ø,LUC4T-N5S-IU-V15,Ìæ´ú¼Ó¸£½ø¿Ú´«¸ÐÆ÷
Ë«¶Ë¿ÚÊä³ö³¬Éù²¨½Ó½ü´«¸ÐÆ÷,UB100-F77-E1-V31,Ìæ´ú¼Ó¸£½ø¿Ú´«¸ÐÆ÷
ËÄÏßÊä³ö³¬Éù²¨½Ó½ü´«¸ÐÆ÷,UB1000-18GM75-PWM-V15,Ìæ´ú¼Ó¸£½ø¿Ú´«¸ÐÆ÷
ÎåÏßÊä³ö³¬Éù²¨½Ó½ü´«¸ÐÆ÷,UB1500-F42-UK-V95,Ìæ´ú¼Ó¸£½ø¿Ú´«¸ÐÆ÷
¹«Ë¾Ãû³Æ£º ¸£¿Æ´«¸ÐÆ÷ÓÐÏÞ¹«Ë¾
µç »°£º 0752 2299448 / ³ÂÑ©Ãá
ÊÖ»ú£º 13790755137
µØ Ö·£º ¶«Ý¸Êг¤°²Õò³¤°²½Ö198
ÓÊ ±à£º 516023
Ö÷ Ò³£º www.gerfk.com
  • 8MM½Ó½ü¿ª¹Ø
  • M4¾Û¹â´«¸ÐÆ÷,СÐ͹âѧ̽ͷ
  • M5¹âµç¿ª¹Ø³¬Ð¡Ð͹âµç´«¸ÐÆ÷
  • º£ÑóÉ豸ÓÃ,IP69·À»¤µÈ¼¶½Ó½ü¿ª¹Ø
  • Ä͵Íνӽü¿ª¹Ø,Äͳ¬µÍνӽü¿ª¹Ø
  • Ä͸ßνӽü¿ª¹Ø
  • Ä͸ßѹÁ¦½Ó½ü¿ª¹Ø
  • Ä£ÄâÁ¿³¬Éù²¨´«¸ÐÆ÷
  • »·Ðνӽü¿ª¹Ø
  • ·Ç½Ó´¥µç¸Ðʽ½Ó½ü¿ª¹Ø
