西门子QFM2160温湿度传感器
Operating voltage
AC 24, DC 13.5...35 V
Sensing element, temperature
DC 0...10 V
Measuring range, temperature
0...50, -35...35, -40...70 °C
Measurement range humidity
0...95 % r.h.
Measurement accuracy
Humidity at 30...70 % r.h. and 23 °C: ±3, Temperature, at 15...35 °C: ±0.8, Temperature, at 35...50 °C: ±1.0 % r.h.
Time constant
Humidity: <20, Temperature in with 2 m/s moved air: <3.5 s (faulty format)
Immersion length
90...154 mm
Connection, electrical
Screw terminals
Type of fixing
Flange
Analog output, signal
DC 0...10, DC 4...20 V
Signal output temperature
DC 0...10 V
Signal output humidity
DC 0...10 V
Degree of protection
IP54
Dimensions (W x H x D)
80 x 88 x 39 mm
