免费注册 登录 | 广告服务 | 客服中心
中华工控网 → 工控产品 → TAKEX 竹中光电传感器DL-S100P
产品名称: TAKEX 竹中光电传感器DL-S100P
型 号: DL-S100P
价 格: 0.00
品 牌:
Rating/Performance/Specification
Detection method Limited range reflective
Detecting distance 0.2-1m *1
Power supply 24-240VAC/DC ±10% 50/60Hz
Current consumption DC power supply: 30 mA or less / AC power supply: 4 W or less
Output mode Relay output 1a 3A 250 V 750 VA AC or less resistive load
3A 30 V 90 W DC or less resistive load
Operation mode Light ON/Dark ON selectable (with switch)
Response time 20ms or less
Hysterisis 10% of detecting distance or less
Light source (light wavelength) Infrared LED (880 nm)*
Light receiving element 2 segment photodiode
Indicator OP.L: operation indicator (red LED)
UP: stability indicator (green LED)
Volume(VR) NEAR/FAR: Optical distance adjustment
Switch(SW) Light ON/Dark ON selector switch L.ON: Light ON
D.ON: Dark ON
Short circuit protection 0
Material Body: polycarbonate / Front, terminal cover: acrylic
Connection Terminal block
Weight Approx. 170 g (including mounting bracket)
Accessories Mounting bracket, operation manual
Environmental Specification
Ambient light 10000 lx or less
Ambient temperature -25 - +55C (no freezing)
Ambient humidity 35~85%RH (no condensation)
Protective structure IP65
Vibration 10-55 Hz / 1.5 mm double amplitude / 2 hours each in 3 direction
Dielectric withstanding 2000 VAC for 1 minute (between input/output terminals and case)
Insulation resistance 500 VDC, 100 MΩ or higher
公司名称: 深圳市创丰仪器仪表有限公司
电 话: 0755 29796001-806 / 钱军辉
手机: 13143436561
地 址: 深圳市宝安九区白金酒店商务大厦1001-1002室
邮 编: 518052
主 页: www.Lansea.net
  • ZCMD25施耐德限位开关组件
  • 施耐德ZCMD21限位开关零部件
  • XCM-D2516L3施耐德限位开关零部件
  • XCM-D2516L1限位开关零部件
  • Panasonic松下GD-C1双层重叠检测器
  • 全新原装松下聚焦镜FX-LE2
  • omron欧姆龙W4S1-03B可编程控制器
  • omron欧姆龙E39-R3不锈钢外壳小型光电传感器
  • OMRON欧姆龙D4E-1D10N 限位开关
  • KEYENCE基恩士光幕电源线GL-RP10P
