Power supply
12 - 24VDC ±10% / Ripple 10% or less
Current consumption
40 mA or less
Output mode
Control
output (*) : Open collector output / Rating: Source current 100 mA (30 VDC) or less / Residual voltage: 1 V or less
Stability
Operation mode
Light ON/Dark ON selectable
Timer
On delay/off delay/disabled selectable (by switch)
Delay time: about 40 ms fixed
Response time
With switch at 4 (turbo function disabled): 250 μs or less
With switch at 8 (turbo function enabled): 500 μs or less
Light source (wavelength)
Blue LED (470nm)
Indicator
Operation indicator: orange LED / Stability (STB) indicator: green LED
Volume (VR)
SENS: sensitivity adjustment volume (8-turn without stopper equipped with indicator)
Switch (SW)
* Light ON/Dark ON selector switch: L.ON for Light ON, D.ON for Dark ON
* Timer selector switch: NOR. for ON/OFF operation, ON.D for on delay (40 ms), OFF.D for off delay (40 ms)
* Mutual Interference prevention/turbo mode selector switch (common)
8:Mutual Interference prevention for up to 8 units, turbo function enabled
4:Mutual Interference prevention for up to 4 units, turbo function disabled
Provided
Short circuit protection
Provided
Material
Polycarbonate
Connection
Attached cable (outer diameter: 4.8mm) 0.2mm2, 4 cores, 2m
Weight
approx. 80 g (including cables and mounting bracket)
Accessory
Mounting bracket, screwdriver for adjustment, light shielding sticker (excluding H type), instruction manual
