免费注册 登录 | 广告服务 | 客服中心
中华工控网 → 工控产品 → 竹中光电传感器UM-Z3SV
产品名称: 竹中光电传感器UM-Z3SV
型 号: UM-Z3SV
价 格: 0.00
品 牌:
竹中光电传感器UM-Z3SV
Rating/Performance/Specification
Detection method
Convergent
reflective
Detecting distance
5-30mm
(50x50mm white
drawing paper)
Detection object
Opaque, translucent, transparent
Power supply
12-24V DC±10% / Ripple 10% or less
Current consumption
27mA
or less
Output mode
NPN open collector
Rating: sink current 80mA (30 VDC) or less
Operation mode
(See the Type table in the previous page)
Response time
0.5ms or less
Hysteresis
Up to 10% of detecting distance
Light source (light wavelength)
Red LED (640nm)
Indicator
Operation indicator (red LED),
Stability indicator (green LED)
Volume (VR) *
in-line
sensitivity
adjustment
Material
Case : Liquid crystalline polyester (filler: polypropylene)
Lens : Polycarbonate
Connection
Attached cable (dia. 2.8)
0.15 mm2 x 3 cores 2m (black)
Weight
Approx.
40g
Notes
* The distance between the sensor and the in-line volume for sensitivity adjustment is fixed to 300mm.
Accessory
Instruction manual, mounting screws, washers, nuts,
screwdriver for adjustment (attached to the model whose model number ends with “V”)
Environmental Specification
Ambient light
3,000 lx or less
Ambient temperature
-25 - +55C (non-freezing)
Ambient humidity
35-85%RH (non-condensing)
Protective structure
IP64
Vibration
10 - 55 Hz / 1.5 mm double amplitude / 2 hours each in 3 direction
公司名称: 深圳市创丰仪器仪表有限公司
电 话: 0755 29796001-806 / 钱军辉
手机: 13143436561
地 址: 深圳市宝安九区白金酒店商务大厦1001-1002室
邮 编: 518052
主 页: www.Lansea.net
  • ZCMD25施耐德限位开关组件
  • 施耐德ZCMD21限位开关零部件
  • XCM-D2516L3施耐德限位开关零部件
  • XCM-D2516L1限位开关零部件
  • Panasonic松下GD-C1双层重叠检测器
  • 全新原装松下聚焦镜FX-LE2
  • omron欧姆龙W4S1-03B可编程控制器
  • omron欧姆龙E39-R3不锈钢外壳小型光电传感器
  • OMRON欧姆龙D4E-1D10N 限位开关
  • KEYENCE基恩士光幕电源线GL-RP10P
