´¦ÀíÆ÷
Supports new 2nd & 3rd gen Intel® Core™ family, Pentium, Celeron series processors in LGA1155 socket
оƬ
Intel® H61 Express Chipset
ÄÚ´æ
º Dual-channel DDR3 Memory architecture
º Supports DDR3 1600/1333 non-ECC, Un-buffered SDRAM Memory
º 2 X 240-pin DDR3 DIMM socket
º Support up to 16 GB*
º * Due to the operation system limitation, the actual memory size may be less than 4GB for the reservation for system usage under Windows® 32-bit OS. For Windows® 64-bit OS with 64-bit CPU, there is no such limitation
À©Õ¹²Û
1 X PCI Express X16 Gen 3.0 slot(s)
1 X PCI Express X 1 Gen 2.0slot(s)
´æ´¢
Support by H61 Express Chipset
• 4 X Serial ATAII 3Gb/s
6-Channel HD audio CODEC
ÍøÂç
º Atheros AR8161 Gigabit Fast Ethernet Controller
º Wake-On-LAN
¹æ¸ñ³ß´ç
•MATX 190 mm(W) X 170mm(H)
ºóI/OÃæ°å
1 X PS/2 Keyboard & PS/2 mouse connectors
º 1 X Audio port (Line Out/Line In/Mic In)
º 1 X RJ-45 port
º 1 X D-Sub (VGA) port(s)
º 4 X USB2.0 port(s)
°åÔØ½Ó¿Ú
º 1 X 24-pin ATX Power Supply connector
º 1 X 4-pin 12V Power connector
º 1 X 4-pin CPU_FAN connector
º 1 X 3-pin SYS_FAN connector
º 1 X Front panel audio header
º 2 X USB 2.0 header
• Support additional 4 USB ports
º 4 X SATA II 3Gb/s connector(s)
º 1 X CLR_CMOS header
