Öлª¹¤¿ØÍø ¡ú ¹¤¿Ø²úÆ· ¡ú ³¬±¡Ç¶ÈëʽÖ÷°åNM70(1037)
²úÆ·Ãû³Æ£º ³¬±¡Ç¶ÈëʽÖ÷°åNM70(1037)
ÐÍ ºÅ£º NM70(1037)
 Ö÷°åNM70(1037) £¨¾ßÌå¼Û¸ñÇëÓë¿Í·þÁªÏµ£©
³¬±¡£¬¸ßÎȶ¨ÐÔ £¬LVDSÖ§³Ö´óÆÁ£¨Ë«6£¬Ë«8£©
CPU:Intel  Dual core Celeron 1037 1.8G
´æ´¢£ºÖ§³Ö±ê×¼2.5 ´çSATAÓ²ÅÌ£¬¿É°²×°MSATA SSD¹Ì̬ӲÅÌ
ÍøÂ磺MINI PCIE½Ó¿Ú£¬¿É°²×°WIFIÎÞÏßÍøÂç
¹©µç£º12V 5AÖ±Á÷¹©µç
CPU
On board Intel 1037U (dual core 1.8G four thread, 2 * 256KB level two cache, 3MB level three cache) processor
CPU single power supply design
Chipset
Intel HM65 chipset
Graphic Interface Support DirectX 10.1 R Support Full HD 1080P Bluray / HD-DVD HD player
Memory
Support for DDR3 1333/1066 non-ECC, Un-buffered SDRAM memory
2 X DDR3 SO-DIMM slot
The maximum memory capacity testing is 16 GB
Storage
2 X Mini PCI Express X1 slot (one of which support the M-SATA disk)
2 X ATAII 3Gb/s
Ethernet
Realtek 8105E 10/100 MB Ethernet chip
Audio
Integrated Realtek ALC662 5.1 channel sound card
Support audio output (external audio port)
The built-in function for discharge
Other Port
Audio jack (2 X-ray output, minimum inhibitory concentration (MIC)
1 RJ - 45 interface
1 x HDMI interface
1 * D sub interface (VGA)
Interface (8 x 4 USB2.0 external, 4 built-in pin)
1 DC input interface of X
CPU _ fan interface X 1
The 1 x system fan connector
LVDS connector x 1
The 2 power supply connector X SATA
Factor
Mini ITX 170x170mm
´Ë°åÁíÓÐI3-3217U,I5-3337U°åÐÍ£¬»¶Ó­×Éѯ
DSC_0145
DSC_01
DSC_0152
¹«Ë¾Ãû³Æ£º ¹ãÖÝÎýÑîµç×ÓÓÐÏÞ¹«Ë¾
µç »°£º 020 22109677 / Àî±£¾ü
ÊÖ»ú£º
µØ Ö·£º ¹ãÖÝÊÐÌìºÓÇøÌìºÓ±±Â·900ºÅ¸ß¿Æ´óÏÃA539
ÓÊ ±à£º 510898
Ö÷ Ò³£º http://www.xyang.com.cn
  • ECS H61H-G11 ³¬±¡Ö÷°å£¬Ë«ÏÔÖ÷°å£¬Ò»Ìå»úÖ÷°å
  • ¹¤Òµµ×°åXY-6S4 ATµçÔ´¡¢ATXµçÔ´¡¢6²Ûλ
  • ±Ú¹Òʽ·À³¾¹¤¿Ø»úÏäXY-6051£¬6²Û»úÏä
  • ÑÐÏé±Ú¹Òʽ¹¤Òµ»úÏä IPC-6805E
  • µÍ¹¦ºÄÖ÷°åNM70-ITX 1037U ATX¹©µç¡¢¸ßÇå½Ó¿Ú
  • ÑÐÏ鯽°åµçÄÔPPC-1561V µÍ¹¦ºÄ¹¤ÒµÆ½°åµçÄÔ
  • ÑÐÏéСÐͽô´ÕÐÍÕû»úIPC-620
  • ¹¤ÒµÆ½°åµçÄÔPPC-1201 £¬D2550µÍ¹¦ºÄ³¬±¡ÎÞ·çÉÈ
  • ¹¤¿ØÖ÷°åXYD2550DC8 µÍ¹¦ºÄÖ÷°å 8COMÖ÷°å
  • ÑÐÏéÈ«ÐÂÉè¼ÆµÚ3´ú4U19"±ê×¼ÉϼÜÕû»úIPC-820
