| ECS TIGD-CI3 MINI-ITX ǶÈëʽÖ÷°å¹æ¸ñ |
| ÐͺŠ|
• ECS TIGD-CI3 |
| ´¦ÀíÆ÷ |
• Onboard Intel Dual Core Atom D525 processor
• DMI 667Mb/s |
| оƬ×é |
• Intel® NM10 Express |
| ϵͳÄÚ´æ |
• Single-channel DDR3 memory architecture
• 2 x 204-pin DDR3 DIMM socket support up to 4GB
• Support DDR3 800 SO DIMM
Due to the operating system limitation, the actual memory size may be less than 4GB for the reservation for system usage under Windows?32-bit OS.
For Windows?64-bit OS with 64-bit CPU, there is no such limitation |
| ͼÐÎÏÔʾ |
• Integrated Intel® Graphics Media Accelerator 3150(GMA3150)
• Integrated DirectX 9 graphics processor
• Max DVMT Graphics Memory up to 384MB |
| À©Õ¹²å²Û |
• 1 x PCI Solt |
| °åÔØ´®ÐÐ ATA |
• Support by Intel® NM10 Express
• 2 x Serial ATA 3.0Gb/s devices |
| °åÔØ LAN |
• Realtek 8105E 10/100 Lan
• Realtek 8111E Giga Lan (Optional) |
| °åÔØÒôЧоƬ |
• Realtek ALC662 6-channel HD audio CODEC
• Compliant with HD audio specification |
| ÄÚ²¿ I/O ½Ó¿Ú |
• 1 x 24-pin ATX Power Supply connector
• 1 x 4-pin CPU_FAN connector
• 1 x Front panel switch/LED header
• 1 x Front panel audio header
• 1 x Clear CMOS header
• 2 x USB 2.0 headers support additional 4 USB 2.0 Ports
• 1 x 4-pin SYS_FAN connector
• 2 x SATA 3Gb/s connectors |
| ºóÃæ°å I/O ½Ó¿Ú |
• 1 x PS/2 keyboard & PS/2 mouse connectors
• 1 x D-sub(VGA)
• 1 x Serial port (COM1)
• 1 x Parallel Port
• 1 x RJ45 LAN connector
• 1 x Audio port (Line-in, Line-out, Mic-in)
• 4 x USB 2.0 Ports |
| BIOS |
• AMI BIOS with 8Mb SPI Flash ROM
• Supports Plug and Play, STR (S3) / STD (S4) , Hardware monitor, Multi Boot
• Audio, LAN, can be disabled in BIOS
• F11 hot key for boot up devices option
• Support eJIFFY |
| ϵͳ¼à¿ØºÍ¹ÜÀí |
• CPU µçѹ¼à¿Ø
• ÍøÂ绽ÐÑ£¨Wake-on-LAN£©¡¢¼üÅÌ¿ª»ú£¨Keyboard-Power-on£©¡¢¶¨Ê±¿ª»ú£¨Timer-Power-on£©
• ϵͳµçÔ´¹ÜÀí
• AC ¶Ïµç»Ö¸´»úÖÆ |
| ²Ù×÷ϵͳ |
• Windows 2000/XP
• Linux
• Win CE
• XPe |
| ¹¤×÷»·¾³ÎÂ¶È |
0°C~ 60°C |
| ¹¤×÷»·¾³Êª¶È |
0% ~ 93%£¨Ïà¶Ôʪ¶È£»ÎÞÀäÄý£© |
| °åÐÍ |
• Mini-ITX
• 17 cm x 17 cm |
