²úÆ·Ãû³Æ£º
µÍ¹¦ºÄ¡¢¸ßÐÔÄÜǶÈëʽÖ÷°åECS VX900-I
ÐÍ ºÅ£º
ECS VX900-I
µÍ¹¦ºÄ£¬¸ßÐÔÄÜ ECS VX900-I ǶÈëʽÖ÷°å£¨¾ßÌå¼Û¸ñÇëÓë¿Í·þÁªÏµ£©
Ïêϸ½éÉÜ
Type
MINI-ITX
Mode
VX900-I
System Specification
CPU
VIA Single Core VX900 1.6G Processor
System Memory
DDR3 1066MHZ DIMM X2 Solt Max 8GB
Chipset
vx900
BIOS Flash
AMI 8Mbit Falsh
Super IO Chipset
ITE 8728F
Display Specification
LCD Interface
Single-Channel 18 bit LVDS up to1366x768
Graphic Resoultion
VGA Mode: up to 1920*1080
Graphic Controller
DX9
Multiple Display
VGA+LVDS£¨HDMI¡¢DVI¿ÉÑ¡)
Audio
Codec
VIA VT1705 HD AUDIO Codec
Audio Interface
line-in,line-out,Mic in
Ethernet
LAN
Single Broadcm Gbe Controller
Ethernet Interface
1xRealtek RTL8111E
I/O Ports Specification
Rear I/O
1XRJ-45
2XPS/2(KB/MS)
1XRS-232
1XDVI
4XUSB
1XVGA
1XAUDIO JACK
Internal I/O
2x RS-232 by pin-header
1x LPT PIN Header
1xLVDS by 2X10pin-header
4xUSB by pin-header
2xSATA II
Expension Slot
1XMini PCIe
2X DIMM
1XPCI
1XPCIe(x1)slot
Mechanical and Environment
Width
170
Depth
170
Operating Temperature
0 deg.C to 60 deg.C
Storage Temperature
10-95%rh @400C non-Condensing
OS Support
Windows 7,Windows XP
