产品名称: 天硕(TOPSSD)T5040工业DOM电子硬盘_2GB
型  号: T5040DOM02GB
TOPSSD T5040 Disk-On-Module fits into any platform with an 40PIN IDE(PATA) interface and provides a simple, fast path upgrade. Designed for industrial embedded applications that require a speedy booting process, the T5040 Disk-On-Module upgrades the working environment efficiently and enhances data transfer rates with read and write performances of up to 50MB/s and 30MB/s respectively. In addition , it's shock proof and low power consumption SSD characteristics makes it the ideal choice as a storage solution.
 基本描述
型    号
   T5040DOM02GB
容    量
     2GB
闪存类型
   SLC NAND Flash
读写速度
   Read: 30MB/s, Write: 20MB/s
接    口
   40PIN IDE(PATA) Interface
传输模式
   PIO Mode:0-6, Multi word DMA Mode: 0-4, Ultra DMA Mode: 0-4
 可靠性
校验修正
   4 symbols in a 512 Bytes sector with additional CRC
损耗控制
     Static and Dynamic wear-leveling
MTBF
     >3 million hours
插拔寿命
   Testing Condition: 3sec/cycle – Repeated Plug/Unplug 10,000 cycles
 工作环境
工作温度
   -20℃~ +70℃
存储温度
   -55℃~ +125℃
湿    度
   10-95% Relative Humidity (Non-dewfall)
抗 冲 击
   1500G@0.5ms
抗 振 动
     Sine (Non-op) : 20Grms,7~2000Hz / Random Vibration(op) : 6Grms, 10~500Hz
 电源需求
输入电压
   DC +5.0V ± 10%
电源模式
   Auto Stand-by and Sleep Mode
功    耗
   <95mA in operation
 规格与保修
外形尺寸
    59.1mm x 27.2mm x 7.4mm
重    量
    <12g
保修期限
    5 years
关 键 词: 天硕 电子硬盘 工业
公司名称: 深圳天硕科技有限公司
联 系 人: 魏丽
电  话: 0755-83708588
手  机: 13699797271
地  址: 深圳市福田区华强北华强广场A座
邮  编: 518000
天硕(TOPSSD)T5(T5040DOM04GB)
天硕(TOPSSD)T5(T5040DOM01GB)
TOPSSD天硕(T5050CF01GB)
TOPSSD天硕(T5050CF08GB)
TOPSSD天硕(T5050CF02GB)
TOPSSD天硕(T5050CF16GB)
TOPSSD天硕(T5050CF04GB)
