CAP2000+×µ°åÕ³¶È¼Æ-±êÅ䣺
ÒÇÆ÷Ö÷»ú
Ť¾Ø·¶Î§Ñ¡Ôñ£º
¸ßŤ¾Ø£¨ICI¹æ¸ñ±ê×¼£©£º1810,00dyne.cm
µÍŤ¾Ø£º7,970dyne.cm
Ò»Ö§Óû§Ñ¡¶¨µÄ×¶ÐÍת×Ó
ζȿØÖÆÑ¡Ôñ£ºµÍÎÂLÐÍ »ò ¸ßÎÂHÐÍ
CAP2000+×µ°åÕ³¶È¼Æ-Ó¦Óãº
ÖеÈÕ³¶ÈÁ÷Ìå
ÈÈÈÛ½º¡¢Í¿ÁÏ ¡¢Ê÷Ö¬
½¨ÖþÍ¿ÁÏ¡¢¹¤ÒµÍ¿ÁÏ¡¢µí·Û
Æû³µÍ¿ÁÏ£¨¸ßÐÔÄÜ£©¡¢Ë¿Ó¡ÓÍÄ«¡¢±íÃæ´¦Àí
˪Àà¡¢ÓлúÈܼÁ¡¢UVÍ¿ÁÏ
ʳƷ¡¢ÓÍÆá¡¢¹âÁÁ¼Á
Äý½º¡¢ÔìֽͿÁÏ
¿ÚÏãÌÇ¡¢ËÜÁÏÈܽº
¸ßÕ³¶ÈÁ÷Ìå
½ºÕ³¼Á¡¢Äý½º¡¢ÃÜ·â¼Á
Á¤Çà¡¢ÓÍÄ«£¨Ô²Öé±ÊÓÍÄ«/Ó¡Ë¢ÓÍÄ«£©¡¢Æ¬×´Ä£ËÜÆ¬
ÇÉ¿ËÁ¦¡¢ÌÇÃÛ¡¢½¹ÓÍ
ºÏ³É¾ÛºÏÎï¡¢¸àÌå¡¢ÒÒϩ֬Àà
»·Ñõ»¯ºÏÎï¡¢Îݶ¥²ÄÁÏ
CAP2000+×µ°åÕ³¶È¼Æ-CAP׶ת×ÓÕ³¶È²âÁ¿·¶Î§£¨²´£©£º
MODEL HIGH TORQUE
13.3N
67ul
CAP-01
13.3N
38ul
CAP-01
13.3N
24ul
CAP-03
3.3N
134ul
CAP-04
3.3N
67ul
CAP-05
3.3N
30ul
CAP-06
2.0N
1700ul
CAP-07
2.0N
400ul
CAP-08
2.0N
100ul
CAP-09
5.0N
170ul
CAP-10
1000+@750rpm
25-2.5
.5-5
.1-10
.2-20
4-40
10-100
N/A
N/A
N/A
N/A
1000+@900rpm
.2-2
.4-4
.8-8
.1-16
3-33
8-83
N/A
N/A
N/A
N/A
1000+@400rpm
357-4.6
75-9.3
1.5-18.7
3-37.5
6-75
15-187
78-7.81*
3.13-31.3*
12.5-125*
.1-10*
1000+@5-1000rpm
2-375
4-750
8-1.5K
1-3K
3-6K
8-15K
78-625*
3.13-2.5K*
12.5-10K*
1-1K*
LOW TORQE(for application requiring low shear rates for low/medium viscosity fliuds,an optional low torque797-7970dyne.cm instrument can be order
1000+@100rpm
2-81
2-1.6
33-3.3
65-6.5
1.3-13
3.3-33
13-1.3
54-5.4
2.2-22
22-2.2
2000+@5-1000rpm
.2-16
2-32
2-66
2-130
2-260
2-260
2ÔÂ26ÈÕ
2-108
2-440
2-44
ul=microliter K=1thousand P=poise 1 Pa.s=10 poise N=RPM e.g Cone CPA-01 13.3×10(rpm)=133sec
Maxmum speed recommend with this spindle is 400rpm. Viscosity rangle indicated is for operation at 400rpm. =Special speed instrument.
Note:Viscosity range shown above are for illustation. The exact range will depend upon instrument configuration.
CAP2000+×µ°åÕ³¶È¼Æ-ÌØµã£º
°´¼üÃæ°å£º¿ÉÖ±½ÓÊäÈë²âÊÔ²ÎÊý
×¶ÐÍת×Ó£ºÒ×ÓÚ²ðжÇåÏ´
¼òµ¥Ò×ÓõĶ¨Î»°ÑÊÖ£º×¼È·×Ô¶¯¶¨Î»×¶ÐÍת×Ó
רÃŵÄÖØ¸´²âÊÔÉè¼Æ
4ÐÐÏÔʾÆÁ£º¿Éͬʱä¯ÀÀËùÓвâÊÔ²ÎÊý
×Ô¶¯×¶/¼ä϶¶¨Î»
Ö»ÐèСÁ¿ÑùÆ·£ºÉÙÓÚ1ml
ÄÚÖÃPeltier Plate
ÑùÆ·¼ÓÈÈ×°ÖãºL ϵÁУº5¡æ-75¡æ H ϵÁУº50¡æ-235¡æ
Õ³¶ÈÖµ·¶Î§
cP(mPa.S) תËÙ
MODEL
Min
Max
RPM
Number of increments
CAP 1000+
see chart on
900/750
2
CAP 2000+
5-1k
995
