¼ò½é:
WLS-T02ÊÇÒ»¿îµç³Ø¹©µçµÄ2.4GHzÎÞÏß·¢ÉäÆ÷(¼ò³ÆTag)£¬¿É¶¨Ê±Ö÷¶¯¹ã²¥2.4GHzÎÞÏß¶¨Î»·â°ü¸øWLS-R01¡£WLS-T02µÄÎÞÏ߯µÂÊʹÓÃISM 2.4GHzÈ«ÇòͨÓÃÆµ¶Î£¬¹²¿É·ÖΪ16¸öÏàÁ򵀮µµÀ(RF Channel)£¬·Ö±ðÿ5MHzΪһ¸öƵµÀ·Ö²¼ÔÚ2.405GHz~2.480GHz£¬ÒÔ¼°Ö§³Ö16¶ÎÎÞÏß·¢ÉäÇ¿¶ÈÉ趨£¬Óû§½Ô¿É͸¹ý°´¼ü½øÐе÷Õû¡£
³ý´ËÖ®Í⣬WLS-T02Ìṩ·äÃùÆ÷¡¢µÍµçÁ¿Ö¸Ê¾µÆ£¬ÒÔ¼°ÄÚ½¨½ÚµãÕ¾ºÅ(Node ID)Óë3dBi PCBÖ¸ÏòÐÍÌìÏß…µÈÈËÐÔ»¯Éè¼Æ£¬¿ÉÓÐЧËõСÌå»ýÒÔÅä¹ÒÔÚÔ¤¼Æ×·×ÙλÖõÄÉ豸£¬Óû§¿É´ÓÔ¶³Ì¿ªÆô·äÃùÆ÷Ãù½Ð¹¦ÄÜ£¬ÐÖúÓû§¿ìËÙÕÒµ½Åä¹ÒWLS-T02É豸¡£
ÁíÍ⣬WLS-T02¾ßÓÐ100¹«³ß¿Õ¿õÖ±Ïß¿ÉÊÓͨѶ¾àÀë(LOS,line of sight)£¬ÇÒÄÚ²¿²ÉÓõͺĵçÉè¼Æ¼Ü¹¹£¬µ±°²×°1¿ÅCR123Aµç³Ø(3.0VDC)£¬Ä¬ÈÏÎÞÏß·¢ÉäÖÜÆÚΪ3Ã룬ÇÒ²Ù×÷ζÈÔÚ20~60¡æÊ±£¬Ê¹ÓÃʱ¼ä¿É³¤´ï1Ä꣬ûµçʱ¿É×ÔÐиü»»ÐÂµç³Ø£¬·Ç³£ÊʺÏÔËÓÃÔÚÎïÆ·×·×Ù¡¢¹¤³§ÇøÓò¹ÜÀíµÈ¶àÖÖÓ¦Óá£
ÌØÉ«:
. Ö§³Ö16¶ÎÎÞÏ߯µµÀÉ趨
. Ö§³Ö16¶ÎÎÞÏß·¢ÉäÇ¿¶ÈÉ趨
. ÄÚ½¨·äÃùÆ÷ÓëÖ§³ÖÔ¶³Ì¿ªÆôÃù½Ð¹¦ÄÜ
. ÄÚ½¨µÍµçÁ¿Ö¸Ê¾µÆ
. ÄÚ½¨2.4GHz 3dBi PCBÖ¸ÏòÐÍÌìÏß
. ʹÓà ISM 2.4GHz È«ÇòͨÓÃÆµ¶Î
. ʹÓÃDSSSÎÞÏßչƵ¼¼Êõ
. ÎÞÏß´«Ê䷶Χ¿É´ï 100 ¹«³ß ( ¿Õ¿õÖ±Ïß¿ÉÊÓ¾àÀë )
. µÍºÄµçÉè¼Æ (1 ¿Å CR123A µç³Ø£¬ÔÚ +20~+60¡æ»·¾³¿ÉÓà 1 Äê)
¹æ¸ñ:
ÎÞÏß¹æ¸ñ
µ÷±ä
OQPSK (Offset Quadrature Phase-shift Keying)
չƵ
DSSS (Direct-Sequence Spread Spectrum)
RFƵµÀÊýÁ¿
16
´«Ê书ÂÊ
16±1dBm (Ô¤Éè) / 17dBm (×î´ó)
ÎÞÏ߯µÂÊ
2.4GHz
ÌìÏß
2.4GHz-3dBi PCBÖ¸ÏòÐÍÌìÏß
´«Êä¾àÀë (LOS)
100¹«³ß (Ô¤Éè)
Ó²¼þ
°´¼üÅäÖÃ
½â³ýÃù½Ð¼ü*2¡¢·äÃùÆ÷*1
·äÃùÆ÷ÒôÁ¿
55dB@10 ¹«·Ö
LEDָʾµÆ
°´Ñ¹°´¼ü
Â̵Æx1
Çó¾È/µç³ØµÍµçÁ¿
ºìµÆx1
EMS±£»¤
ESD
±4 kVÓÚ½Ó´¥ÂÝË¿
EFT (IEC 61000-4-4)
±4 kVÓÚµçÔ´
µçÔ´
ÊäÈëµçѹ
+2.6 VDC ~ +3.6 VDC
µç³ØÊýÁ¿
1 x CR123A (3.0 VDC)
¹¦ºÄ
(1.) ·äÃùÆ÷²»Ãù½Ð£º
267uW@3VDC/2.13mAh@1Ìì (·¢ÉäÖÜÆÚ3Ãë)
(2.) ·äÃùÆ÷Ãù½Ð:
90mW@3VDC/30mAh@1Сʱ (·¢ÉäÖÜÆÚ3Ãë¡¢ÇÒÃù½ÐÖÜÆÚ1Ãë)
»ú¹¹
³ß´ç(³¤x¿íx¸ß)
70 mm x 43 mm x 21 mm
°²×°
¹Ò¹´
»·¾³
²Ù×÷ζÈ
-25 ~ 70¡æ (²»º¬µç³Ø)
-25 ~ 60¡æ (º¬µç³Ø)
´¢´æÎ¶È
-30 ~ 80¡æ (²»º¬µç³Ø)
-20 ~ 45¡æ (º¬µç³Ø)
Ïà¶Ôʪ¶È
45 ~ 85% RH (ÎÞÄý¶£¬²»º¬µç³Ø)
20 ~ 65% RH (ÎÞÄý¶£¬º¬µç³Ø)
¶©¹ºÐÅÏ¢:
WLS-T02 CR
ÎÞÏß¶¨Î»ÏµÍ³Ö®·¢ÉäÆ÷ (RoHs)
ÖØÒªÌáÐÑ£ºÎÞÏß¶¨Î»ÏµÍ³Ö®·¢ÉäÆ÷Ðè´îÅä½ÓÊÕÆ÷¡¢×ª»»Æ÷Ò»ÆðʹÓã¬Çë²Î¿¼WLS-R01ÓëRFU-400¡£
×¢£ºÖ»ÏÞÑÇÖÞÏúÊÛ¡£
Åä¼þÐÅÏ¢:
WLS-R01 CR
ÎÞÏß¶¨Î»ÏµÍ³Ö®½ÓÊÕÆ÷ (RoHs)
WLS-CFG CR
ÎÞÏß¶¨Î»ÏµÍ³Ö®ÅäÖÃÆ÷ (RoHS)
RFU-400 CR
RS-232/RS-485 to 429 MHz ÎÞÏßÊý¾Ýת»»Æ÷ (RoHS)
ï®µç³Ø(CR123A)
µçѹ3.0V£¬ÈÝÁ¿1700mAh (Ò»´ÎÐÔ²»¿É³äµçï®µç³Ø)
