免费注册 登录 | 广告服务 | 客服中心
中华工控网 → 工控产品 → RCS-9000F GTX1080
产品名称: RCS-9000F GTX1080
型 号:
价 格: 0.00
品 牌:
采用英特尔®第七代Kaby Lake工作站等级英特尔®至强®/酷睿™ i7处理器和2560 CUDA® 核心英伟达GeForce® GTX 1080独立显卡,最高可支持8K分辨率,最多支持7个独立高清视频;配备多组PCI/PCIe插槽、前控式2.5寸硬盘抽取盒、高速数字接口、显示接口,高性能与高扩充性双栖,32个通道隔离DIO,支持10V至36V直流输入及80V浪涌保护,内建智能电流防护功能,优化的操控性、产品功能高度集成。
产品规格
System
Processor
Quad Core Intel® Xeon®/Core™ i7 Processor
(Kaby Lake-S/Skylake-S)
Chipset Intel® C236
BIOS AMI
SIO IT8786E
Memory 2 DDR4 2133MHz SO-DIMM, up to 32GB
OS Windows 10, Windows 8.1, Windows 7, Linux
I/O Interface
Serial  4 COM RS-232/422/485 (ESD 8KV)
USB
- 7 USB 3.0 (6 External, 1 Internal)
- 2 USB 2.0 (Internal)
Isolated DIO 32 Isolated DIO : 16 DI, 16 DO
LED Power, HDD
SIM Card  3 SIM Card Socket (2 External, 1 Internal)
Expansion
Mini PCIe
3 Mini PCIe Socket :
- 2 Full-size Mini PCIe for PCIe/USB/External SIM Card
- 1 Full-size Mini PCIe for PCIe/USB/Internal SIM Card/mSATA
PCIe Up to 2 PCIe Slot, by request
PCI Up to 2 PCI Slot, by request
Graphics
Processor
- Intel® HD Graphics 630/530
- NVIDIA GeForce® GTX 1080
Interface
8 Display interfaces:
- 3 DVI : Up to 1920 x1200 @ 60 Hz
- 3 DisplayPort : Up to 7680 x 3840 @ 60Hz
- 1 DisplayPort : Up to 4096 x 2304 @ 60Hz
- 1 HDMI : Up to 4096 × 2160 @ 60Hz
Storage
SATA 4 SATA III (6Gbps) support S/W RAID 0, 1, 5, 10
mSATA 1 SATA III (Mini PCIe Type, 6Gbps)
Storage Device
- 1 CFast Socket (Internal)
- 4 2.5" SSD/HDD Bracket (Internal)
Audio
Audio Codec Realtek ALC892, 5.1 Channel HD Audio
Audio Interface 1 Mic-in, 1 Line-out
Ethernet
LAN 1 Intel® I219LM GigE LAN supports iAMT 11.0
LAN 2 Intel® I210 GigE LAN
Power
Power Input 10V to 36V, DC-in
Power Interface 3-pin Terminal Block : V+, V-, Frame Ground
Ignition Control 16 Mode (Internal)
Remote Switch 3-pin Terminal Block
Surge Protection Up to 80V/1ms Transient Power
Others
TPM Optional Infineon SLB9665 supports TPM 2.0, LPC Interface
Watchdog Timer Reset : 1 to 255 sec./min. per step
Smart Management Wake on LAN, PXE supported
HW Monitor Monitoring temperature, voltages. Auto throttling control when CPU overheats.
Mechanical
Dimension (W x L x H) 172mm x 330mm x 210mm (6.8" x 13" x 8.3")
Weight
RCS-9400FHR GTX1080 : 6.3 kg (13.9 lb)
RCS-9400FR GTX1080 : 5.6 kg (12.3 lb)
Mounting Wallmount by mounting bracket
Environment
Operating Temperature
35W TDP CPU :
- Core™ i7 : -25°C to 60°C (-13°F to 140°F)
- Xeon® E3-1268L v5 : -25°C to 60°C (-13°F to 140°F)
65W TDP CPU :
Core™ i7 : -25°C to 55°C (-13°F to 131°F)
80W TDP CPU :
Xeon® E3-1275 v6, E3-1275 v5, E3-1225 v5 : -25°C to 45°C (-13°F to 113°F)
Storage Temperature -40°C to 85°C (-40°F to 185°F)
Humidity 5% to 95% Humidity, non-condensing
Relative Humidity 95% at 60°C
Shock IEC 60068-2-27, SSD: 50G @ wallmount, Half-sine, 11ms
Vibration IEC 60068-2-64, SSD: 5Grms, 5Hz to 500Hz, 3 Axis
EMC CE, FCC, EN50155, EN50121-3-2
公司名称: 昆山市安卓电子有限公司
电 话: 0512 57359033-602 / 周光
手机: 15995602827
地 址: 巴城镇东荣路136号华水工业园1号楼
邮 编: 215300
主 页: http://www.vecow.com
  • 工控机EVS-1000
  • RCS-9000F GTX1080
  • ECS-9100 GTX1050
  • PE-2004
  • IVH-9200MXC (M12)
  • EMBC-1000-300U
  • ECS-9240 GTX1050
