免费注册 登录 | 广告服务 | 客服中心
中华工控网 → 工控产品 → 工控机EVS-1000
产品名称: 工控机EVS-1000
型 号: EVS-1000
价 格:
品 牌:
产品特色
    • 无风扇,-25°C 至 60°C 工作温度
    • 工作站等级第7代英特尔® 至强®/酷睿™ i7/i5/i3处理器 (Kaby Lake) 与C236芯片组
    • 紧凑型英伟达GeForce® GT 1030独立显卡,英伟达Pascal™ GPU架构,最高可支持8K分辨率
    • 1个VGA、1个DVI、4个Displayport显示接口,最多可支持5个独立高清显示
    • 前控支持:2个2.5寸硬盘抽取盒、1个CFast卡插槽、6个USB 3.0插槽
    • 3个SIM插槽,支持WiFi/4G/3G/LTE/GPRS/UMTS
    • 扩充支持:1个PCI/PCIe 插槽、3个Mini PCIe插槽
    • 2个SATA III接口、4个COM RS-232/422/485串口
    • 32个光电隔离DIO、10V至36V直流输入、80V浪涌保护
    • 支持电源延缓开关机设定 (车载模式)
产品规格
System
Processor Quad Core Intel® Xeon®/Core™ i7/i5/i3 Processor (Kaby Lake-S/Skylake-S)
Chipset Intel® C236
BIOS AMI
SIO IT8786E
Memory 2 DDR4 2133MHz SO-DIMM, up to 32GB (ECC/Non-ECC)
OS Windows 10, Windows 8.1, Windows 7, Linux
I/O Interface
Serial  4 COM RS-232/422/485 (ESD 8KV)
USB
- 6 USB 3.0 (External)
- 1 USB 2.0 (Internal)
Isolated DIO 32 Isolated DIO : 16 DI, 16 DO
LED Power, HDD
SIM Card  3 External SIM Card Socket
Expansion
Mini PCIe
3 Mini PCIe Socket :
- 3 Full-size for PCIe/USB/External SIM Card/mSATA
PCI/PCIe 1 PCI/PCIe x4 Slot
SUMIT A, B 2 SUMIT Slot (Optional)
Graphics
Processor
- Intel® HD Graphics 630/530
- NVIDIA® GeForce® GT 1030 (MXM Module)
Interface
6 Display interfaces:
- 1 VGA : Up to 1920 x 1200 @ 60Hz
- 1 DVI : Up to 1920 x 1200 @ 60Hz
- 2 DisplayPort : Up to 4096 x 2304 @ 60Hz
- 2 DisplayPort : Up to 7680 x 3840 @ 60Hz
Storage
SATA 2 SATA III (6Gbps) support S/W RAID 0, 1
mSATA 3 SATA III (Mini PCIe Type, 6Gbps)
Storage Device
- 1 CFast Socket, Push-in/Push-out Ejector
- 2 Front-access 2.5" SSD/HDD Tray
Audio
Audio Codec Realtek ALC892, 5.1 Channel HD Audio
Audio Interface 1 Mic-in, 1 Line-out
Ethernet
LAN 1 Intel® I219LM GigE LAN supports iAMT 11.0
LAN 2 Intel® I210 GigE LAN
Power
Power Input 10V to 36V, DC-in
Power Interface 3-pin Terminal Block : V+, V-, Frame Ground
Ignition Control 16 Mode (Internal)
Remote Switch 3-pin Terminal Block
Surge Protection Up to 80V/1ms Transient Power
Others
TPM Optional Infineon SLB9665 supports TPM 2.0, LPC Interface
Watchdog Timer Reset : 1 to 255 sec./min. per step
Smart Management Wake on LAN, PXE supported
HW Monitor Monitoring temperature, voltages. Auto throttling control when CPU overheats.
Mechanical
Dimension (W x L x H) 260mm x 215mm x 79mm (10.2" x 8.5" x 3.1")
Weight 4.2 kg (9.26 lb)
Mounting
- Wallmount by mounting bracket
- DIN Rail Mount
- 2U Rackmount (Optional)
Environment
Operating Temperature -25°C to 60°C (-13°F to 140°F)
Storage Temperature -40°C to 85°C (-40°F to 185°F)
Humidity 5% to 95% Humidity, non-condensing
Relative Humidity 95% at 60°C
Shock IEC 60068-2-27, SSD: 50G @ wallmount, Half-sine, 11ms
Vibration IEC 60068-2-64, SSD: 5Grms, 5Hz to 500Hz, 3 Axis
EMC CE, FCC, EN50155, EN50121-3-2
公司名称: 昆山市安卓电子有限公司
电 话: 0512 57359033-602 / 周光
手机: 15995602827
地 址: 巴城镇东荣路136号华水工业园1号楼
邮 编: 215300
主 页: http://www.vecow.com
  • 工控机EVS-1000
  • RCS-9000F GTX1080
  • ECS-9100 GTX1050
  • PE-2004
  • IVH-9200MXC (M12)
  • EMBC-1000-300U
  • ECS-9240 GTX1050
