处理器 Intel® Core™ i7-4650U (2 x 1.7 / 3.3 GHz, 4M Cache, 15W)
Intel® Core™ i5-4300U (2 x 1.9 / 2.9 GHz, 3M Cache, 15W)
Intel® Core™ i3-4010U (2 x 1.7 GHz, 3M Cache, 15W)
Intel® Celeron® 2980U (2 x 1.6 GHz, 2 M Cache, 15 W)
芯片组 Integrated in SoC
BIOS AMI Aptio® 2.X (UEFI) BIOS
SM-BIOS
BIOS Update
Logo Boot
Quiet Boot
HDD Password
图形显示 Next Generation Intel® HD Graphics
with OpenCL 1.2, OpenGL 4.0 and DirectX11.1 support; up to three independent displays:
内存 max. 16 GByte DDR3 1600 MHz
输入输入接口 1x Front Panel HD Audio
1x Serial Port COM1 (opt. as ccTALK)
1x Serial Port COM2
1x Feature connector - congatec custom (8 Bit General Purpose I/O)
2x LAN RJ45 Intel® I218-LM GbE LAN Controller with AMT 9.5 support
8x USB 3.0/2.0
声音 High Definition Audio Interface
视频接口 HDMI 1.4, DVI, DP, VGA
1x LVDS (2x24 bit)
1x Embedded DisplayPort (x4)
1x Backlight (Power, control)
2x DisplayPort dp++
存储接口 3x SATA (6G)
1x mSATA (SATA-III; 600)
1x SATA Power
扩展接口 1x Full/Half-size Mini PCIe Slot shared with PCIe x1 slot (with SIM slot)
1x Full/Half-size Mini PCIe Slot (shared with mSATA)
PCIe x4 Slot (Gen.2)
1x PCIe x4 (via extension card)
电源 1x internal power header (12-19V)
1x opt. battery header signal + power (SBM3)
1x DC-In (external input) 12V / 19-24V @ 5A max.
尺寸 Thin-Mini-ITX board
工作湿度 Operating: 10 to 90% r. H. non cond. / Storage 5 to 95% r. H. non cond.
