ÍøÂçÐÍI/OÄ£¿é¾ß2-port Ethernet Switch¼°16-ch Power RelayÊä³ö
¼ò½é:
ET-2261-16Ä£¿é¾ßÓÐÒÔÌ«ÍøÂçºÍÊý×ÖI/O¼à¿Ø¹¦ÄÜ£¬¿É͸¹ý10/100 M ÒÔÌ«ÍøÂçʹÓÃModbus TCP/UDP ÐÒéÀ´×öÔ¶³Ì¿ØÖÆ¡£¶øModbus ÊÇÏÖ½ñÁ¬½Ó¹¤Òµµç×ÓÉ豸·½Ê½ÖÐ×îÆÕ±éÇÒ³£ÓõĹ¤Òµ±ê׼ͨÐÅÐÒé¡£Òò´ËÈÃET-2261-16Ä£¿éÄܹ»ÓëHMI, SCADA, PLC¼°ÆäËüÈí¼þϵͳÕûºÏÒ»ÆðʹÓá£
ET-2261-16Ä£¿éÌṩ16 ¸ö¸ß¹¦Âʼ̵çÆ÷ (Power Relay) Êä³öͨµÀ£¬»¹ÌṩÓÐ2-PortµÄEthernet Switch£¬ ¿ÉʹÓà Daisy-Chain µÄ½ÓÏßÀ´´®Á¬É豸£¬Ê¹Æä°²×°Éϸü¾ßÁé»îÐÔ£¬²¢ÇÒ¼ò»¯°²×°¼°½µµÍ»ù´¡ÉèÊ©³É±¾¡£ET-2261-16Ä£¿é»¹¾ßÓÐ8 kV ¾²µç·Åµç (ESD) ·À»¤¡¢4kV µç¿ìËÙ˲±ä (EFT) ·À»¤¡¢3 kV µçÓ¿·À»¤ÒÔ¼°3000 VDC Êä³öÈë¸ôÀ룬ÔÚ¹¤Òµ»·¾³ÖÐÒ²¼ÓÇ¿ÁËÔëÉù·À»¤ÄÜÁ¦¡£
Ò²Ö§³ÖÁËI/O Pair-connection¹¦ÄÜ£¬Í¸¹ýÒÔÌ«ÍøÂçÀ´²úÉúDIºÍDOµÄÔ¶¾àÂß¼¹ØÁ¬£¬Ò»µ©Íê³ÉÉ趨£¬Ä£¿é±ã¿ÉÔÚ±³¾°ÏÂʹÓÃModbus/TCPͨѶÐÒ飬³ÖÐøµØ¶ÁÈ¡ÏÖ³¡µÄ DI ״̬£¬²¢ÇÒдµ½Ô¶³ÌµÄ DO É豸¡£ÌرðÊÊÓÃÓÚÁ¬½ÓһЩ²»¾ßÓÐÒÔÌ«ÍøÂ繦ÄܵÄÊý×ÖI/O É豸¡£
ET-2261-16Ä£¿éʹÓÃÒ»¿Å 32λµÄ ARM MCU À´¸ßЧµÄ¿ØÖÆÍøÂç·â°üµÄÊÕËÍ£¬»¹ÅäÖÃÁ˿ɲðжʽµÄ½ÓÏß¶Ë×ÓÁ¬½ÓÆ÷£¬Ê¹½ÓÏß·½±ãÇÒÈÝÒס£ET-2261-16Ä£¿éÊÇרΪ³¬µÍ¹¦ºÄ£¬½µµÍ¶îÍâµçÁ¦³É±¾À´Éè¼ÆµÄ£¬ÌرðÊÇÔÚʹÓÃÁË´óÁ¿µÄÉ豸µÄÇé¿öϸüÏÔÖØÒª¡£ÄÜÑ¡ÔñÕâÖÖ½ÚÄÜÉ豸À´½µµÍµçÁ¦ÏûºÄ£¬Ò²ÊÇΪÁËά»¤Õâ¸öÂÌÉ«»·¾³À´½øÒ»·ÖÐÄÁ¦¡£
ÌØÉ«:
oÄÚ½¨ÍøÒ³·þÎñÆ÷
oÖ§³ÖModbus TCP/UDP ÐÒé
oʹÓÃ32 λ MCU À´ÓÐÐ§ÕÆÎÕÍøÂçÁ÷
oÖ§³Ö2-port µÄEthernet Switch (LAN Bypass) ¿É´®Á¬³ÉDaisy-Chain½ÓÏß
oÖ§³ÖË«ÖØ¿´ÃŹ·»úÖÆÉè¼Æ
o¿É͸¹ýÍøÂç¼òµ¥Ñ¸Ëٵĸüй̼þ
oÄÚ½¨I/O ¹¦ÄÜ16¸öPower Relay Êä³öÐŵÀ
oÖ§³Ö LED ÏÔʾI/O ״̬¹¦ÄÜ
oÖ§³ÖI/O Pair-connection (Push¼°Polling) ¹¦ÄÜ
oeSearch UtilityÖ§³Ö 32-/64-bit Windows XP/2003/2008/7/8/10²Ù×÷ϵͳ
o¿ÉÔË×÷ÓÚ -25°C ~ +75°CÖ®¹¤×÷»·¾³
o·ûºÏ RoHS»·±£¹æ·¶
¸ü¶àÐÅÏ¢Çë²Î¿¼: ET-2261-16 ²úÆ·ÍøÒ³
