28/20¿Ú°ÙÕ×·ÇÍø¹ÜÐ͹¤ÒµÒÔÌ«Íø½»»»»ú²ÉÓøßÇ¿¶ÈIP40·À»¤Íâ¿Ç£¬¹¤Òµ¼¶EMCÉè¼Æ£¬°üÀ¨CRS3120¡¢CRS3128Á½¿î£¬ÊÇÉîÛÚÊÐѶ¼Ç¿Æ¼¼ÓÐÏÞ¹«Ë¾×ÔÖ÷Ñз¢µÄ¶þ²ãÒÔÌ«Íø½»»»»ú¡£²úÆ·Ìṩ16¸ö¹Ì¶¨10/100/1000M×ÔÊÊÓ¦ÒÔÌ«Íø¶Ë¿Ú¡¢4¸ö¹Ì¶¨1000Base-X module £¨Ö§³Öµ¥Ä£ºÍ¶àÄ££©»ò1000Base-T module £¨Ö§³ÖË«½ÊÏß´«Ê䣩SFP½Ó¿ÚºÍ¿ÉÑ¡8¸ö100/1000Base-FX¹â¿Ú£¨Ä¬ÈÏSC½Ó¿Ú£¬¿ÉÑ¡FC¡¢ST£©»ò8¸ö10/100/1000M×ÔÊÊÓ¦ÒÔÌ«Íø¶Ë¿Ú¡£»ùÓÚ¹¤Òµ°²×°ÐèÇó£¬Ìṩ1U±ê×¼»ú¼Üʽ°²×°·½Ê½¡£±¾²úƷͬʱ²ÉÓÃÎÞ·çÉÈ¡¢µÍ¹¦ºÄ¡¢¹¤Òµ¼¶Éè¼Æ£¬-40~75¡æ¹¤×÷ζȷ¶Î§£¬Äܹ»Âú×ã¸÷ÖÖ¹¤ÒµÏÖ³¡µÄÒªÇó£¬Ìṩ±ã½ÝµÄÒÔÌ«ÍøÍ¨Ñ¶½â¾ö·½°¸¡£
¼¼Êõ ±ê×¼£ºIEEE802.3¡¢IEEE802.3u¡¢IEEE 802.3z¡¢IEEE802.3x¡¢IEEE802.1Q¡¢IEEE802.1p ¡¢IEEE802.1d¡¢IEEE802.1w ½Ó¿Ú RJ45µç¿Ú£º10/100/1000Base-T(X)ËÙÂÊ×ÔÊÊÓ¦¡¢È«/°ëË«¹¤Ä£Ê½£¬MDI/MDI-X×ÔÊÊÓ¦ SFP½Ó¿Ú£º1000Base-X»òSFP Copper 1000Base-T£¨Ö§³ÖË«½ÊÏß´«Ê䣩 ¹â¿Ú£º1000Base-FX°ÙÕ×ȫ˫¹¤£¬Ä¬ÈÏSC½Ó¿Ú£¬¿ÉÑ¡FC¡¢ST£¬×îÔ¶¿É´«Êä120¹«Àï Console¿Ú£ºRS-232£¨RJ45Á¬½ÓÍ·£©µ÷ÊÔ´®¿Ú ½»»»ÊôÐÔ Ê®Õ×ת·¢ËÙ¶È£º14881pps °ÙÕ×ת·¢ËÙ¶È£º148810pps ǧÕ×ת·¢ËÙ¶È£º1488096pps ´«Ê䷽ʽ£º´æ´¢×ª·¢ ϵͳ½»»»´ø¿í£º12.8Gbps »º´æ´óС£º1.5Mbits MACµØÖ·±í£º16K µçÔ´ ½»Á÷µçÔ´£ºÈßÓà¿íµçѹ100~240V AC(50~60Hz 1.2A)µçÔ´ÊäÈ룬²ÉÓÃÈýÏàµçÔ´Ïß Ö±Á÷µçÔ´£ºÈßÓà¿íµçѹ36~48V DCµçÔ´ÊäÈ룬²ÉÓÃ4о7.62mm¼ä¾à±ê×¼¹¤Òµ¶Ë×Ó£¬µçÔ´Ö§³Ö·À·´½ÓºÍÎÞ¼«ÐÔ¹¦ÄÜ ¼ÌµçÆ÷ ¼ÌµçÆ÷¸æ¾¯Êä³ö£º¶Ë¿Ú¹ÊÕÏ¡¢µçÔ´¹ÊÕϺͻ·Íø¹ÊÕϵĸ澯Êä³ö ´¥µã×î´óÈÝÁ¿£º1A@24VDC »úÐµÌØÐÔ ³ß´ç£¨W×H×D£©£º482.6mm×44mm×322.5mm ¾»ÖØ£º5kg Íâ¿Ç£ºIP40µÈ¼¶±£»¤£¬½ðÊôÍâ¿Ç °²×°£º1U±ê×¼»ú¼Ü ¹¤×÷»·¾³ ¹¤×÷ζȣº-40¡æ~75¡æ ´æ´¢Î¶ȣº-40¡æ~85¡æ Ïà¶Ôʪ¶È£º5%~95%£¨ÎÞÄý¶£© ±£ÐÞ ±£ÐÞÆÚ£º5Äê ·ûºÏ±ê×¼ IEC61000-4-2£¨ESD£©£º±6KV½Ó´¥·Åµç£¬±15KV¿ÕÆø·Åµç IEC61000-4-3£¨RS£©£º10V/M£¨80-1000MHZ£© IEC61000-4-4£¨EFT£©£ºµçÔ´¶Ë£º±4KV£¬ÐźŶˣº±2KV IEC61000-4-5£¨Surge£©£ºµçÔ´¶Ë£º±4KV CM/±2KV DM£¬ÐźŶˣº±4KV IEC61000-4-6£¨É䯵´«µ¼£©£º3V£¨10KHZ-150KHZ£©£¬10V£¨150KHZ-80MHZ£© IEC61000-4-16£¨¹²Ä£´«µ¼£©£º30V(cont.),300V(1s) IEC60068-2-6£¨Õñ¶¯£© IEC60068-2-27£¨³å»÷£© IEC60068-2-32£¨×ÔÓɵøÂ䣩 IEC61000-6-2£¨Í¨Óù¤Òµ±ê×¼£©£¬IEC61750-3£¨±äµçÕ¾£©£¬IEEE1613£¨µçÁ¦·ÖÕ¾£© EN50121-4£¨¹ìµÀ½»Í¨£©
¹«Ë¾¼ò½é ²úƷĿ¼ ¹©Ó¦ÐÅÏ¢
