µÂ¹úHBM·Å´óÆ÷²úÆ·½éÉÜ£º
AE101·Å´óÆ÷Êǵ¹úHBMÖ±Á÷·Å´óÆ÷µ¥¶ËʽֱÁ÷·Å´óÆ÷£¬ÐèÒªÕý½ÇÉèÖü¶¼äÖ±Á÷µçƽ¡£µÂ¹úHBMÖ±Á÷·Å´óÆ÷AE101µç·ÊÇÀûÓõç×èRO2µæ¸ßµÚ¶þ¼¶·¢É伫µç룬Ìá¸ßV1µÄ¼¯µç¼«µçλ£¬Ê¹µÂ¹úHBM AE101·Å´óÆ÷Á½¹Ü¶¼¹¤×÷ÔÚ·Å´óÇø
µÂ¹úHBM·Å´óÆ÷Ïà¹ØÐͺţº
AE101:
Ϊ¾²Ì¬ºÍ¶¯Ì¬²âÁ¿µÄÓ¦±äÈ«ÇŵÄDC·Å´óÆ÷(6kHz)£»¿ÉÑ¡Ôñ¼¤Àøµçѹ£»0.1 ... 8mV/VÁ¿³Ì
AE301:
Ó¦±äÈ«ÇÅÔØ²¨·Å´óÆ÷(600Hz)£º·Ç³£¸ßµÄÁãµãÎȶ¨ÐÔ£»×îda4¸öÓ¦±äƬ?reg;Áª²Ù×÷£»0.03%ÏßÐÔÆ«²î£»0.2 ... 8mV/VÁ¿³Ì
AE501:
µç¸ÐÈ«ÇźͰëÇÅÔØ²¨·Å´óÆ÷(4.8 kHz)£»8 ... 400mV/VÁ¿³Ì
GR201:
Á½¸ö¶ÀÁ¢Êä³öµÄË«ÏÞλ¿ª¹Ø£»²Î¿¼µçѹ¿ÉÌô£º–10V µ½ +10V£¬¿ª¹Ø·½Ïò£¬ÖͺóºÍ¿ª¹ØÊ±¼ä¿Éµ÷¡£
TS101:
×Ô¶¯È¥Æ¤ºÍ´¢´æµ¥Ôª£»Ë²¼äºÍ·åÖµÊýÖµ²É¼¯£»°üÂçÇúÏß¹¦ÄÜÑ¡ÔñEM201, EM201K2: +20mAµ¥/Ë«find stage »ò +4 ...+20mAµçÁ÷Êä³ö£»ÔÊÐí¸ºÔØ×èÖµ< 500 Ohm
EM201, EM201K2:
Ä£¿éµçÔ´(230V, 115V/50 ...60Hz)£»×îda4¸öÄ£¿é?reg;Áª(15V= / max. 650mA);¹ýÔØ±£»¤¡£<500 Ohm
NT101A, NT102A:
µÂ¹úHBM·Å´óÆ÷¼°Ïà¹Ø²úÆ·ÐͺŴóÈ«£º
¹©Ó¦µÂ¹úHBM´«¸ÐÆ÷Z6ϵÁУº
Z6FC3/20KG Z6FC3/50KG Z6FC3/100KG Z6FC3/200KG Z6FC3/500KG Z6GC3/500KG Z6FC3/1T Z6FD1/5KG Z6FD1/10KG Z6FD1/20KG Z6FD1/50KG Z6FD1/100KG
Z6FD1/200KG Z6FD1/500KG Z6FD1/1T Z6FC3/10KG Z6FC4/20KG Z6FC4/50KG Z6FC4/100KG Z6FC4/200KG Z6FC4/500G K-Exi-Test Z63AC3/50KG Z63AC3/100KG Z63AC3/200KG
¹©Ó¦µÂ¹úHBM´«¸ÐÆ÷C2 ϵÁÐ
C2/50KG C2/100KG C2/200KG C2/500KG C2/1T C2/2T C2/5T C2/10T C2/20T C2/50T C2AC3/Eexd C2AC3/1T/EExd 2AC3/2T/EExd C2AC3/5T/EExd C2AC3/10T/EExd
¹©Ó¦µÂ¹úHBM´«¸ÐÆ÷C16 ϵÁÐ
C16AD1/20T C16AD1/30T C16AD1/40T C16AD1/60T C16AD1/100T C16A/200T C16AC3/15T C16AC3/20T C16AC3/30T C16AC3/40T C16AC3/60T C16AC3/100T
K-Exi-Test Lightning Protection 20m cable with metal braiding
¹©Ó¦µÂ¹úHBM´«¸ÐÆ÷Êý×Öʽ´«¸ÐÆ÷
C16iC3/20T C16iC3/30T C16iC3/40T C16iC3/60T Èí¼þTRADE RTNi1C3/33T RTNi1C3/47T RTNi1C3/68T
¹©Ó¦µÂ¹úHBM´«¸ÐÆ÷FITϵÁÐ
FIT/H1SR2/5KG FIT/H1SR2/10KG FIT/H1SR2/20KG FIT/H1SR2/50KG
FIT/H1SR2/75KG FIT/H1SR5/5KG FIT/H1SR5/10KG FIT/H1SR5/20KG
FIT/H1SR5/50KG FIT/H1SR5/75KG FIT/H1DR2/5K FIT/H1DR2/10K
FIT/H1DR2/20K FIT/H1DR2/50K FIT/H1DR2/75K FIT/H1DR5/5K
FIT/H1DR5/10K FIT/H1DR5/20K FIT/H1DR5/50K FIT/H1DR5/75K
PW18iSR2/5KG PW18iSR2/10KG PW18iSR2/20KG PW18iSR2/50KG
PW18iSR2/75KG PW18iSR5/5KG PW18iSR5/10KG PW18iSR5/20KG
PW18iSR5/50KG PW18iSR5/75KG PW18iDR2/5KG PW18iDR2/10KG
PW18iDR2/20KG PW18iDR2/50KG PW18iDR2/75KG PW18iDR5/5KG
PW18iDR5/10KG PW18iDR5/20KG PW18iDR5/50KG PW18iDR5/75KG
¹©Ó¦µÂ¹úHBM´«¸ÐÆ÷HLC ϵÁÐ
HLCA(B)D1/220KG HLCA(B)D1/550KG HLCA(B)D1/1100KG HLCA(B)D1/1760KG HLCA(B)D1/2200KG HLCA(B)D1/4400KG HLCA(B)C3/220KG
HLCA(B)C3/550KG HLCA(B)C3/1100KG HLCA(B)C3/1760KG HLCA(B)C3/2200KG HLCA(B)C3/4400KG HLCBD1/10T HLC_£¨1£©D1-220KG HLC_£¨1£©D1-550KG HLC_£¨1£©D1-1.1t HLC_£¨1£©D1-1.76t HLC_£¨1£©D1-2t HLC_£¨1£©D1-2.2t HLC_£¨1£©D1-4.4t HLC_(1)C3-220KG HLC_(1)C3-550kg HLC_(1)C3-1.1t HLC_(1)C3-1.76t HLC_(1)C3-2.2t HLC_(1)C3-4.4t
¹©Ó¦µÂ¹úHBM´«¸ÐÆ÷RTNϵÁÐ
RTN 0,05/1t RTN 0,05/2.2t RTN 0,05/4.7t RTN 0,05/10t RTN 0,05/15t RTN 0,05/22t RTN 0,05/33t RTN 0,05/47t RTN 0,05/68t RTN 0,05/100t RTN 0,05/150t RTN 0,05/220t RTN 0,05/330t RTN 0,05/470t
RTN C3/1t RTN C3/2.2t RTN C3/4.7t RTN C3/10t RTN C3/15t RTN C3/22t RTN C3/33t RTN C3/47t RTN C3/68t RTN C3/100t RTN C3/150t RTN C3/220t RTN C3/330t RTN C3/470t
¹©Ó¦µÂ¹úHBM´«¸ÐÆ÷H35ϵÁÐ
H35/500lbs H35/1k lbs H35/2.5k lbs H35/4k lbs H35/5k lbs
¹©Ó¦µÂ¹úHBM´«¸ÐÆ÷B35ϵÁÐ
B35/250lbs B35/500lbs B35/1k lbs B35/2k lbs B35/2.5k lbs B35/3k lbs B35/4k lbs B35/5k lbs
MB35ϵÁÐ 0.22,0.55,1.1,1,76T 2.2,4.4T
S40ϵÁÐ
S40/50KG S40/100KG S40/200KG S40/500KG S40/1t S40/2t S40/3t S40/5t
¹©Ó¦µÂ¹úHBM´«¸ÐÆ÷RSCϵÁÐ
RSCAC1/50KG RSCAC1/100KG RSCAC1/200KG RSCAC1/500KG
RSCAC1/1T RSCAC1/2T RSCAC1/5T RSCAC3/500KG RSCAC3/1T
RSCAC3/2T RSCAC3/5T RSCBC1/200KG RSCBC1/500KG RSCBC1/1T
RSCBC1/2T RSCBC1/5T RSCBC3/200KG RSCBC3/500KG RSCBC3/1T
RSCBC3/2T RSCBC3/5T ATEX
¹©Ó¦µÂ¹úHBM´«¸ÐÆ÷U2AϵÁÐ
U2A/50KG U2A/100KG U2A/200KG U2AD1/500KG U2AD1/1T U2AD1/2T U2AD1/5T U2A/10T U2A/20T K-Exi-Test 120¡æ U2A0.2/50KG U2A0.1/100KG U2A0.1/200KG U2A0.1/500KG U2A0.1/10T U2A0.1/20T
¹©Ó¦µÂ¹úHBM´«¸ÐÆ÷µ¥µãʽ´«¸ÐÆ÷
SP1 20G,30G
SP2 100G,300g
SPL 300,600,1500,3000G
DF6S DF6S/1KG DF6S/2KG DF6S/4KG DF6S/5KG DF6S/10KG DF6S/15KG DF6S/20KG DF6S/30KG
PW2A PW2AC3/7.2KG PW2AC3/12KG PW2AC3/18KG PW2AC3/36KG PW2AC3/72KG PW2AC3MI7.5/7.2KG PW2AC3MI7.5/12KG PW2AC3MI7.5/18KG PW2AC3MI7.5/36KG PW2AC3MI7.5/72KG
PW4KRC3 0.3,0.5,2,3,KG
PW6KR 3,5,10,15,20,30,40KG
PW6KRC3 3,5,10,15,20,30,40KG
PW6KRC3MR 3,5,10,15,20,30,40KG
PW24A PW24AD1/50KG PW24AD1/100KG PW24AD1/150KG PW24AD1/200KG PW24AD1/250KG PW24AD1/300KG PW24AD1/500KG PW24AD1/635KG PW24AC3/50KG PW24AC3/100KG PW24AC3/150KG PW24AC3/200KG PW24AC3/250KG PW24AC3/300KG PW24AC3/500KG PW24AC3/635KG
SP4 SP4D1/1KG SP4D1/3KG SP4D1/5KG SP4D1/7KG SP4D1/10KG SP4D1/15KG SP4D1/20KG SP4D1/30KG SP4D1/50KG SP4D1/75KG SP4D1/100KG SP4D1/200KG SP4C3/1KG SP4C3/3KG SP4C3/5KG SP4C3/7KG SP4C3/10KG SP4C3/15KG SP4C3/20KG SP4C3/30KG SP4C3/50KG SP4C3/75KG SP4C3/100KG SP4C3/200KG
PW10C3 50,100,150,200,250KG
PW12B PW12BD1/50KG PW12BD1/75KG PW12BD1/100KG PW12BD1/150KG PW12BD1/200KG PW12BD1/250KG PW12BD1/300KG PW12BD1/500KG PW12BD1/635KG PW12BD1/1000KG PW12BC3/50KG PW12BC3/75KG PW12BC3/100KG PW12BC3/150KG PW12BC3/200KG PW12BC3/250KG PW12BC3/300KG PW12BC3/500KG PW12BC3/635KG PW12BC3/1000KG
PW15 PW15C3/10KG PW15C3/15KG PW15C3/20KG PW15C3/30KG PW15C3/50KG PW15C3/75KG PW15C3/100KG PW15C3/150KG PW15C3MR/10KG PW15C3MR/15KG PW15C3MR/20KG PW15C3MR/30KG PW15C3MR/50KG PW15C3MR/75KG PW15C3MR/100KG PW15C3MR/150KG
SP10 SP10/2KG SP10/3KG SP10/5KG SP10/7KG SP10/10KG SP10/15KG SP10/20KG SP10/30KG SP10/50KG SP10/90KG
PW16C3 30,50,75,100,150KG£¬200,250,300,500,660KG
PW4MC3 0.3,0.5,2,3,5KG
KF2S-5 KF2S-5/1KG KF2S-5/3KG KF2S-5/5KG KF2S-5/10KG KF2S-5/12KG KF2S-5/15KG KF2S-5/20KG KF2S-3/1KG KF2S-3/1KG KF2S-3/3KG KF2S-3/5KG KF2S-3/10KG KF2S-3/12KG KF2S-3/15KG KF2S-3/20KG
PW6K PW6KD1/3KG PW6KD1/5KG PW6KD1/6KG PW6KD1/7.5KG PW6KD1/10KG PW6KD1/15KG PW6KD1/20KG PW6KD1/25KG PW6KD1/30KG PW6KD1/40KG PW6KC3/3KG PW6KC3/5KG PW6KC3/6KG PW6KC3/7.5KG PW6KC3/10KG PW6KC3/15KG PW6KC3/20KG PW6KC3/25KG PW6KC3/30KG PW6KC3/40KG PW6KC4/3KG PW6KC4/5KG PW6KC4/6KG PW6KC4/7.5KG PW6KC4/10KG PW6KC4/15KG PW6KC4/20KG PW6KC4/25KG PW6KC4/30KG PW6KC4/40KG PW6KC5/3KG PW6KC5/5KG PW6KC5/6KG PW6KC5/7.5KG PW6KC5/10KG PW6KC5/15KG PW6KC5/20KG PW6KC5/25KG PW6KC5/30KG PW6KC5/40KG PW6KC6/3KG PW6KC6/5KG PW6KC6/6KG PW6KC6/7.5KG PW6KC6/10KG PW6KC6/15KG PW6KC6/20KG PW6KC6/25KG PW6KC6/30KG PW6KC6/40KG PW6KC3M17.5/3KG PW6KC3M17.5/5KG PW6KC3M17.5/6KG PW6KC3M17.5/7.5KG PW6KC3M17.5/10KG PW6KC3M17.5/15KG PW6KC3M17.5/20KG PW6KC3M17.5/25KG PW6KC3M17.5/30KG PW6KC3M17.5/40KG
BLC BLC B1 D1/550KG BLC B1 D1/1.1T BLC B1 D1/1.76T BLC B1 C3/550KG BLC B1 C3/1.1T BLC B1 C3/1.76T
ELCB ELCB1/550KG ELCB1/1.1T ELCB1/1.76T ELCB1 HS/220KG ELCB1 HS/550KG ELCB1 HS/1.1T ELCB1 HS/1.76T
RSCA RSCA C1/50KG RSCA C1/100KG RSCA C1/200KG RSCA C1/500KG RSCA C1/1T RSCA C1/2T RSCA C1/5T RSCA C3/500KG RSCA C1/1T RSCA C1/2T RSCA C1/5T
SSC SSC D1/550KG SSC D1/880KG SSCC1/880KG
PW10C3 PW10C3/50KG PW10C3/100KG PW10C3/150KG PW10C3/200KG PW10C3/250KG PW10C3/300KG PW10C3-MR/50KG PW10C3-MR/100KG PW10C3-MR/150KG PW10C3-MR/200KG PW10C3-MR/250KG PW10C3-MR/300KG
JRT JRT/20k lb JRT/50k lb JRT/75k lb JRT/100k lb JRT/150k lb JRT/200k lb
¹©Ó¦µÂ¹úHBM´«¸ÐÆ÷Z6¸½¼þ
Z6/200KG/ZGWR Z6/1T/ZGWR Z6/200KG/ZPL Z6/500KG/ZPL
Z17/2T/ZPL Z6/ZFP/200KG Z6/200KG/ZK Z6/1T/ZK Z6/200KG/ZEL
Z6/1T/ZEL Z6/200KG/ZRR
HLC¸½¼þ
HLCB/ZFP/1.76T HLCB/ZFP/4.4T HLCB/1.76T/ZEL HLCB/10T/ZEL
HLCB/4.5T/ZEL HLCB/ZPU/1.76T HLCB/ZPU/2.2T HLCB/ZPU/4.4T
HLCB/ZAK/1.76T HLCB/ZDP/1.76T HLCB/ZDP/4.4T
RSC¸½¼þ
U1R/200KG/ZGW U2A/1T/ZGUW U2A/5T/ZGUW
U2A¸½¼þ
U2A/1T/ZGOW U2A/2T/ZGOW U2A/5T/ZGOW U2A/10T/ZGOW U2A/20T/ZGOW U2A/1T/ZGUW U2A/2T/ZGUW U2A/5T/ZGUW
U2A/10T/ZGUW U2A/20T/ZGUW
¹©Ó¦µÂ¹úHBM´«¸ÐÆ÷C16¸½¼þ
C16/ZOU44A C16/ZOU44A EPO3/50T EPO3/100T C16/EPU44A
C16/EPU64 EPO3/100T SC232/422A
C2A¸½¼þ
EPO3R/5T ZPS25/66 ZELB/2T ZELB/5T ZELB/10T
C2¸½¼þ
EPO3/200KG EPO3R/5T EPO3R/20T EPO3R/50T ZPS13/44
ZPS25/66 ZPS32/115 ZPS44/150 ZELB/2T ZELB/5T ZELB/10T
ZELA/20T ZELA/50T
¹©Ó¦µÂ¹úHBM´«¸ÐÆ÷RTN¸½¼þ
RTN/2.2T/VEN RTN/4.7T/VEN RTN/22T/VEN RTN/22T/VENR RTN/33T/VEN RTN/47T/VEN RTN/68T/VEN RTN/100T/VEN
RTN/150T/VEN RTN/220T/VEN RTN/330T/VEN RTN/470T/VEN
RTN/1T/VPN RTN/2.2T/VPN RTN/4.7T/VPN RTN/10T/VPN
RTN/15T/VPN RTN/22T/VPN RTN/33T/VPN RTN/47T/VPN RTN/68T/VPN RTN/100T/VPN
¹©Ó¦µÂ¹úHBM´«¸ÐÆ÷³ÆÖØÒÇ±í¼°¸½¼þ
WE2108 WE2108S WE2108S-485 WE2108M WE2108M-485
WE2108/DOC AC/DC15V/550mA WE2110 WE2110DC WE2110/DOC
WE2110/ZM WE2110/ZT WE2110/ZH WE2110/ZCC WE2110/ZS
Mains cable RM4220 AD104-R5 AD101B AD103B AED9101B
AED9201A AED9301A AED/FITDOC SC232/422B
½ÓÏߺÐ
VKK4 VKK1R-4 VKK2-6 VKK2-8 VKK2R-8 VKK2R-8DIGITAL
VKEEX SB01A
³ÆÖØÄ£¿éϵÁÐ
C16/MSL20T(D1¾«¶È)¶ÆÐ¿ C16/MSL20T(C3¾«¶È)¶ÆÐ¿ C16/MSL30T¶ÆÐ¿
C16/MSL40T¶ÆÐ¿ C16/MSL60T¶ÆÐ¿ C16/MSL100T¶ÆÐ¿ C16/MSL200T¶ÆÐ¿ C16/MSLR20T²»Ðâ¸Ö C16/MSLR30T²»Ðâ¸Ö C16/MSLR40T²»Ðâ¸Ö
C16/MSLR60T²»Ðâ¸Ö C16/MSLR100T²»Ðâ¸Ö C16/MSLR200T²»Ðâ¸Ö
HLC/MLB220KG¶ÆÐ¿ HLC/MLB550KG¶ÆÐ¿ HLC/MLB1100KG¶ÆÐ¿ HLC/MLB1760KG¶ÆÐ¿ HLC/MLB2200KG¶ÆÐ¿ HLC/MLB4400KG¶ÆÐ¿
HLC/MLBR220KG²»Ðâ¸Ö HLC/MLBR550KG²»Ðâ¸Ö HLC/MLBR1100KG²»Ðâ¸Ö
HLC/MLBR1760KG²»Ðâ¸Ö HLC/MLBR2200KG²»Ðâ¸Ö HLC/MLBR4400KG²»Ðâ¸Ö
RTNMAR1T,2.2T RTNMAR4.7T RTNMAR10T,15T,22T RTNMA33T(¶ÆÐ¿£©
RTNMLAR1T,2.2T RTNMLAR4.7T RTNMLAR10T,15T,22T RTNMLA33T(¶ÆÐ¿£© RTNMBR1T,2.2T RTNMBR4.7T RTNMBR10T,15T,22T RTNMB33T(¶ÆÐ¿£© RTNMLBR1T,2.2T RTNMLBR4.7T RTNMLBR10T,15T,22T
RTNMLB33T(¶ÆÐ¿£©
SSC µ¥Ö§³ÅLC
SSCD1/550KG SSCD1/880KG
