²úÆ·Ãû³Æ£º
µãÆÁ²âÊÔ-KX-226M
ÐÍ ºÅ£º
KX-226M
µãÆÁ²âÊÔ-KX-226MÌØµã£º
- ×°ÖÃÌå»ýС¡¢±ãÓÚ¸÷ÖÖÏÖ³¡Ê¹ÓÃ
- Ö§³Ö»ÃæÔÚÏßµ÷ÊÔ£¬ÊµÊ±¼à²âÏû·ÑµçÁ÷µÈ¹¦ÄÜ
- ¾ßÓкãѹºÍºãÁ÷±³¹â¿ØÖÆÊä³ö
- ½Ó¿ÚÖ§Ô®RGB/MIPI/eDP/LVDSÐźÅÊä³ö£¨À©Õ¹Ö§³ÖVBOÊä³ö£©
- Äܹ»·Ö±ð¶ÔƵÂÊ¡¢µçѹ¡¢µçÁ÷²ÎÊý¡¢½×µ÷ÖµµÈ½øÐе÷ÕûºÍ²âÒº¾§Ä£×é
- Ö§³Ö¶ÔÓ¦²»Í¬µÄ½Ó¿ÚÐèÇó£¬Í¬Ê±¾ß±¸Ðźż°µçÔ´ÍⲿÀ©Õ¹µÄÁé»îÐÔ
- Äܹ»Í¨¹ýרÓõÄÉÏλ»ú¼°½Å±¾±à³ÌÓïÑÔ±àдģ×é²âÊÔ³ÌÐò£¬Ö§³Ö½çÃæ»¯±à³Ì£¬Ö§³ÖÔÚÏßµ÷ÊÔ¹¦ÄÜ
- Ö§³ÖBMP¡¢ LogicͼƬ¸ñʽÏÔʾ
µãÆÁ²âÊÔ-KX-226M¹æ¸ñ²ÎÊý£º
| ÐÅºÅ½Ó¿Ú |
RGB |
1920×1080 @60Hz (Max) |
| RGB888/RGB666/RGB565 |
| MIPI |
3840×2160 @60Hz (Max) |
| 3840×2160 @DSC Mode |
| C-PHY:3/6 Lane |
| D-PHY:1/2/4/8 Lane |
| 1.5Gbps/Lane (Max) |
| Video Mode & Command Mode |
| 6/8/10 Bit |
| eDP |
2560×1600 @60Hz (max) |
| Ö§³ÖeDP 1.1ºÍeDP 1.2ÐÒé |
| ×Ô¶¯ÊÊÓ¦1.62/2.7Gbps |
| 6/8/10 Bit |
| 1/2/4 Lane |
| LVDS |
2560×1600 @60Hz |
| 4 Channel |
| 6/8/10Bit |
| ÆäËû½Ó¿Ú |
SPI |
3Wire/4Wire,8/9/16 Bit £»500Hz~20MHz |
| SPI * 1 |
| SPI |
100KHz/400KHz |
| I2C * 1 * 4CH |
| GPIO |
Input Voltage Range 0~3.3V |
| ADC * 4 * 4CH |
| GPIO* 4 |
| PWM |
1Hz~1MHz, Duty Ratio 0~100% |
| PWM * 1 |
