Öлª¹¤¿ØÍø ¡ú ¹¤¿Ø²úÆ· ¡ú °ËͨµÀµç×Óʽ¶Ï·Æ÷
²úÆ·Ãû³Æ£º °ËͨµÀµç×Óʽ¶Ï·Æ÷
ÐÍ ºÅ£º ZR-ECB-N-08-24DC/10
Æ· ÅÆ£º Áãµã¿Æ¼¼zerotech
ÊÊÓ÷¶Î§ Application Scope
- 24V DC ¿ª¹ØµçÔ´Êä³ö²à
- 24V DC µçÁ÷·ÖÅä
- PLC¡¢µç´Å·§¡¢´«¸ÐÆ÷¡¢Ö´ÐÐÆ÷µÈ¸ºÔر£»¤
Ö÷Òª¼¼Êõ²ÎÊýMain Technical Parameter
°²×°ÀàÐÍ
Mounting Type
±ê×¼DIN35mmµ¼¹ì°²×°£¬1λ
Standard DIN35mm rail mounting, 1 position
²úÆ·ÀàÐÍ
Product Type
É豸£¨¹ýÁ÷£©¶Ï·Æ÷
Equipment (overcurrent) circuit breaker
±£»¤Í¨µÀ
Protection Channel
8
¾øÔµ·À»¤µÈ¼¶
Insulation Protection Level
III
ÎÛȾµÈ¼¶
Pollution Degree
2
¿í¶È
Width
41mm
¸ß¶È
Height
135mm
Éî¶È
Depth
128mm (°üº¬DIN7.5mmÀàÐ͵¼¹ì)
128mm (Including DIN7.5mm type rail)
µçÆøÌØÕ÷ Electrical Characteristics
¹¤×÷µçѹ·¶Î§ DC Input
Operating Voltage Range  DC Input
18VDC---30VDC
¶î¶¨¹¤×÷µçѹ Un
Rated Operating Voltage  Un
24VDC
×ܶµçÁ÷ I max
Total Rated Current  I Max
Max. 70ADC£¨DC IN£©
µ¥Í¨µÀ¶î¶¨µçÁ÷ In
Single Channel Rated Current  In
1 / 2 / 3 / 4 / 5 / 6 / 7 / 8 / 9 / 10A
Ô¤ÉèµçÁ÷ Is
Preset Current  Is
10A
¶î¶¨µçÓ¿µçѹ Vm
Rated Surge Voltage  Vm
0.5 KV
ÍÑ¿ÛÀàÐÍ
Plug Type
E£¨µç×Óʽ£©
E£¨Electronic£©
²úÆ·¹¦ºÄ W
Product Power Consumption  W
¾²Ì¬Ð¡ÓÚ0.5W
Standby power less than 0.5W
Ä£¿é³õʼ»¯Ê±¼ä ms
Module Initialization Time  ms
Éϵçʱ¼äСÓÚ50ms
Power-on time less than 50ms
¹Ø¶ÏºóÀäȴʱ¼ä S
Cooling Time After Shutdown  s
СÓÚ10S
Less then 10S
µçÁ÷²âÁ¿Îó²î @I
Current Measurement Error  @I
СÓÚ10%
Less then 10%
MTBF £¨IEC61709£¬SN29500£© ²úÆ·ÊÙÃü 600Kh
Product life 600Kh
¹«Ë¾Ãû³Æ£º ³£ÖÝÁãµãÖÇÄܿƼ¼ÓÐÏÞ¹«Ë¾
µç »°£º 400 6055510 / ¾°²½·å
ÊÖ»ú£º 15950584296
µØ Ö·£º ³£ÖÝÊÐÌìÄþÇø´óÃ÷±±Â·1738ºÅÖн»¡¤ÖÇÜö¸Û²úÒµÔ°14#901
ÓÊ ±à£º 213000
Ö÷ Ò³£º http://www.cz-zero.com
  • °ËͨµÀµç×Óʽ¶Ï·Æ÷
  • ËÄͨµÀµç×Óʽ¶Ï·Æ÷
  • µ¥Í¨µÀµç×Óʽ¶Ï·Æ÷
