2.其他更多Windows命令
accwiz.exe > Accessibility Wizard for walking you through setting up your machine for your mobility needs. 辅助工具向导
acsetups.exe > ACS setup DCOM server executable
actmovie.exe > Direct Show setup tool 直接显示安装工具
append.exe > Allows programs to open data in specified directories as if they were in the current directory. 允许程序打开制定目录中的数据
arp.exe > NETWORK Display and modify IP - Hardware addresses 显示和更改计算机的IP与硬件物理地址的对应列表
at.exe > AT is a scheduling utility also included with UNIX 计划运行任务
atmadm.exe > Displays statistics for ATM call manager. ATM调用管理器统计
attrib.exe > Display and modify attributes for files and folders 显示和更改文件和文件夹属性
autochk.exe > Used to check and repair Windows File Systems 检测修复文件系统
autoconv.exe > Automates the file system conversion during reboots 在启动过程中自动转化系统
autofmt.exe > Automates the file format process during reboots 在启动过程中格式化进程
autolfn.exe > Used for formatting long file names 使用长文件名格式
bootok.exe > Boot acceptance application for registry
bootvrfy.exe > Bootvrfy.exe, a program included in Windows 2000 that notifies the system that startup was successful. Bootvrfy.exe can be run on a local or remote computer. 通报启动成功
cacls.exe > Displays or modifies access control lists (ACLs) of files. 显示和编辑ACL
calc.exe > Windows Calculators 计算器
cdplayer.exe > Windows CD Player CD播放器
change.exe > Change { User | Port | Logon } 与终端服务器相关的查询
charmap.exe > Character Map 字符映射表
chglogon.exe > Same as using "Change Logon" 启动或停用会话记录
chgport.exe > Same as using "Change Port" 改变端口(终端服务)
chgusr.exe > Same as using "Change User" 改变用户(终端服务)
chkdsk.exe > Check the hard disk for errors similar to Scandisk 3 Stages must specify a Drive Letter 磁盘检测程序
chkntfs.exe > Same as using chkdsk but for NTFS NTFS磁盘检测程序
cidaemon.exe > Component of Ci Filer Service 组成Ci文档服务
cipher.exe > Displays or alters the encryption of directories [files] on NTFS partitions. 在NTFS上显示或改变加密的文件或目录
cisvc.exe > Content Index -- It's the content indexing service for I 索引内容
ckcnv.exe > Cookie Convertor 变换Cookie
cleanmgr.exe > Disk Cleanup, popular with Windows 98 磁盘清理
cliconfg.exe > SQL Server Client Network Utility SQL客户网络工具
clipbrd.exe > Clipboard viewer for Local will allow you to connect to other clipboards 剪贴簿查看器
clipsrv.exe > Start the clipboard Server 运行Clipboard服务
clspack.exe > CLSPACK used to create a file listing of system packages 建立系统文件列表清单
cluster.exe > Display a cluster in a domain 显示域的集群
_cmd_.exe > Famous command prompt 没什么好说的!
cmdl32.exe > Connection Manager Auto-Download 自动下载连接管理
cmmgr32.exe > Connection Manager 连接管理器
cmmon32.exe > Connection Manager Monitor 连接管理器监视
cmstp.exe > Connection Manager Profile Manager 连接管理器配置文件安装程序
comclust.exe > about cluster server 集群
comp.exe > ComClust Add, Remove, or Join a cluster. 比较两个文件和文件集的内容*
compact.exe > Displays or alters the compression of files on NTFS partitions. 显示或改变NTFS分区上文件的压缩状态
conime.exe > Console IME IME控制台
control.exe > Starts the control panel 控制面板
convert.exe > Convert File System to NTFS 转换文件系统到NTFS
convlog.exe > Converts MS IIS log files 转换IIS日志文件格式到NCSA格式
cprofile.exe > Copy profiles 转换显示模式
cscript.exe > MS Windows Scripts Host Version 5.1 较本宿主版本
csrss.exe > Client Server Runtime Process 客户服务器Runtime进程
csvde.exe > Comma Separated Variable Import/Export Utility 日至格式转换程序
dbgtrace.exe > 和Terminal Server相关
dcomcnfg.exe > Display the current DCOM configuration. DCOM配置属性
dcphelp.exe > ?
dcpromo.exe > Promote a domain controller to ADSI AD安装向导
ddeshare.exe > Display DDE shares on local or remote computer DDE共享
ddmprxy.exe >
debug.exe > Runs Debug, a program testing and editing tool. 就是DEBUG啦!
dfrgfat.exe > Defrag FAT file system FAT分区磁盘碎片整理程序
dfrgntfs.exe > Defrag NTFS file system NTFS分区磁盘碎片整理程序
dfs_cmd_.exe > configures a Dfs tree 配置一个DFS树
dfsinit.exe > Distributed File System Initialization 分布式文件系统初始化
dfssvc.exe > Distributed File System Server 分布式文件系统服务器
diantz.exe > MS Cabinet Maker 制作CAB文件
diskperf.exe > Starts physical Disk Performance counters 磁盘性能计数器
dllhost.exe > dllhost is used on all versions of Windows 2000. dllhost is the hedost process for all COM+ applications. 所有COM+应用软件的主进程
dllhst3g.exe >
dmadmin.exe > Disk Manager Service 磁盘管理服务
dmremote.exe > Part of disk management 磁盘管理服务的一部分
dns.exe > DNS Applications DNS
doskey.exe > recalls Windows command lines and creates macros 命令行创建宏
dosx.exe > DOS Extender DOS扩展
dplaysvr.exe > Direct Play Helper 直接运行帮助
drwatson.exe > Dr Watson for 2000 Fault Detector 华生医生错误检测
drwtsn32.exe > Dr Watson for 2000 viewer and configuration manager 华生医生显示和配置管理
公司名称: 北京昆仑纵横科技发展有限公司
联 系 人: 纵横科技
电  话: 010-51659278
传  真: 010-51659278-101
地  址: 北京市海淀区上地7街1号汇众大厦212室
邮  编: 100085
该厂商相关技术文摘:
HMIBuilder高级培训
常用DOS命令
加油机的科技进步及发展
人机界面(HMI)产品基本常识
人机界面在工业现场的位置分析
昆仑纵横SCADA系统在天津大学空调机组热交换设备中的应用
HMIBuilder宝典
HMIBuilder功能手册
HMIBuilder初级培训
HMIBuilder初级培训
TPC070TD-b说明书
TPC105TD-b说明书
更多文摘...
立即发送询问信息在线联系该技术文摘厂商:
