dtcsetup.exe > Installs MDTC
dvdplay.exe > Windows 2000 DVD player DVD播放
dxdiag.exe > Direct-X Diagnostics Direct-X诊断工具
edlin.exe > line-oriented text editor. 命令行的文本编辑器(历史悠久啊!)
esentutl.exe > MS Database Utility MS数据库工具
eudcedit.exe > Private character editor Ture Type造字程序
eventvwr.exe > Windows 2000 Event Viewer 事件查看器
evnt_cmd_.exe > Event to trap translator; Configuration tool
evntwin.exe > Event to trap translator setup
exe2bin.exe > Converts EXE to binary format 转换EXE文件到二进制
expand.exe > Expand Files that have been compressed 解压缩
extrac32.exe > CAB File extraction utility 解CAB工具
fastopen.exe > Fastopen tracks the location of files on a hard disk and stores the information in memory for fast access. 快速访问在内存中的硬盘文件
faxcover.exe > Fax Cover page editor 传真封面编辑
faxqueue.exe > Display Fax Queue 显示传真队列
faxsend.exe > Fax Wizard for sending faxes 发送传真向导
faxsvc.exe > Starts fax server 启动传真服务
fc.exe > Compares two files or sets of files and their differences 比较两个文件的不同
find.exe > Searches for a text string in file or files 查找文件中的文本行
findstr.exe > Searches for strings in files 查找文件中的行
finger.exe > Fingers a user and displays statistics on that user Finger一个用户并显示出统计结果
fixmapi.exe > Fix mapi files 修复MAPI文件
flattemp.exe > Enable or disable temporally directories 允许或者禁用临时文件目录
fontview.exe > Display fonts in a font file 显示字体文件中的字体
forcedos.exe > Forces a file to start in dos mode. 强制文件在DOS模式下运行
freecell.exe > Popular Windows Game 空当接龙
ftp.exe > File Transfer Protocol used to transfer files over a network connection 就是FTP了
gdi.exe > Graphic Device Interface 图形界面驱动
grovel.exe >
grpconv.exe > Program Manager Group Convertor 转换程序管理员组
help.exe > displays help for Windows 2000 commands 显示帮助
hostname.exe > Display hostname for machine. 显示机器的Hostname
ie4uinit.exe > IE5 User Install tool IE5用户安装工具
ieshwiz.exe > Customize folder wizard 自定义文件夹向导
iexpress.exe > Create and setup packages for install 穿件安装包
iisreset.exe > Restart IIS Admin Service 重启IIS服务
internat.exe > Keyboard Language Indicator Applet 键盘语言指示器
ipconfig.exe > Windows 2000 IP configuration. 察看IP配置
ipsecmon.exe > IP Security Monitor IP安全监视器
ipxroute.exe > IPX Routing and Source Routing Control Program IPX路由和源路由控制程序
irftp.exe > Setup FTP for wireless communication 无线连接
ismserv.exe > Intersite messaging Service 安装或者删除Service Control Manager中的服务
jdbgmgr.exe > Microsoft debugger for java 4 Java4的调试器
jetconv.exe > Convert a Jet Engine Database 转换Jet Engine数据库
jetpack.exe > Compact Jet Database. 压缩Jet数据库
jview.exe > Command-line loader for Java Java的命令行装载者
krnl386.exe > Core Component for Windows 2000 2000的核心组件
label.exe > Change label for drives 改变驱动器的卷标
lcwiz.exe > License Compliance Wizard for local or remote systems. 许可证符合向导
ldifde.exe > LDIF cmd line manager LDIF目录交换命令行管理
licmgr.exe > Terminal Server License Manager 终端服务许可协议管理
lights.exe > display connection status lights 显示连接状况
llsmgr.exe > Windows 2000 License Manager 2000许可协议管理
llssrv.exe > Start the license Server 启动许可协议服务器
lnkstub.exe >
locator.exe > RPC Locator 远程定位
lodctr.exe > Load perfmon counters 调用性能计数
logoff.exe > Log current user off. 注销用户
lpq.exe > Displays status of a remote LPD queue 显示远端的LPD打印队列的状态,显示被送到基于Unix的服务器的打印任务
lpr.exe > Send a print job to a network printer. 重定向打印任务到网络中的打印机。通常用于Unix客户打印机将打印任务发送给连接了打印设备的NT的打印机服务器。
lsass.exe > LSA Executable and Server DLL 运行LSA和Server的DLL
lserver.exe > Specifies the new DNS domain for the default server 指定默认Server新的DNS域
macfile.exe > Used for managing MACFILES 管理MACFILES
magnify.exe > Used to magnify the current screen 放大镜
makecab.exe > MS Cabinet Maker 制作CAB文件
mdm.exe > Machine Debug Manager 机器调试管理
mem.exe > Display current Memory stats 显示内存状态
migpwd.exe > Migrate passwords. 迁移密码
mmc.exe > Microsoft Management Console 控制台
mnmsrvc.exe > Netmeeting Remote Desktop Sharing NetMeeting远程桌面共享
mobsync.exe > Manage Synchronization. 同步目录管理器
