PC3000
Production Process System
理想的:
集成的塑料挤出系统 半导体 - Diffusion & MBE 热处理- 完整的炉子控制, 真空炉, 隧道窑, 热挤压 食品- 烤炉
一个多用途集成模块化的控制系统,采用高生产力的编程工具和IEC1131-3编程语言。 |
I/O 模块:
模拟量输入x 4: mV, T/C, mA, PT100 (indiv. channel isolation and CJC)
模拟量输出 x 4: mV, V
数字量输入 x 14: 24V dc, 240V ac, vfc.
数字量输出 x 12: Relay 1A, Logic
CPU: 68020 w/Floating Point co-processor - LCM-Plus with 3 serial ports (RS422/RS485/RS232)
工作温度 0-50°C 相关湿度: 5 to 95% non-condensing
电源: 85-264V ac
安装: 3U 19' rack (12 modules) panel or bulkhead |
精确的模拟控制
Universal direct sensor inputs with 14-bit resolution. Highly configurable PID control - heat only, heat cool, auto & least squares adaptive tuning, single loop, cascade, ratio, valve positioner and more.
数字量控制
布尔和组合逻辑功能
顺序控制
顺序控制图 (SFC)
策略控制
Built-in calculation of SPC variables, standard deviation, mean, upper and lower control limits and more Ability to use this information for real time Statistical Quality Control (SQC)
通讯
Two user defined and one configuration port Expandable to 16 using the Intelligent Communications Module (ICM) Many Function Block selectable protocols - Ei-Bisynch, Modbus RTU master & slave, Siemens 3964R, Allen-Bradley Simple DIY driver for ASCII interfaces |
