产品名称: 欧陆EUROTHERM 2404 碳势控制器
型  号: 2404
品  牌: 欧陆EUROTHERM
onmouseover="changeImages('request_quote_01', '../../images/request-quote_01-over.gif'); return true;" onmouseout="changeImages('request_quote_01', '../../images/request-quote_01.gif'); return true;" href="http://12.45.162.124/sendtoxsell/sendtoxsell.asp?i=2404cc&c=2404cc">
渗碳炉, 陶瓷窑
直接连接到氧化锆探头
碳势控制, 氧百分含量,露点
CO 或 H2 补偿
探头结垢处理, 探头维护, 探头清洁
Modbus®, Profibus®, 或 DeviceNet™ 通讯
PID控制 ,阀位控制和直流DC重发
The 2404 Atmosphere Controllers provide accurate display and control of carbon level in carburizing furnaces and ceramic glazing kilns. There are three different controllers that connect to a variety of common zirconia probes, including the Series AP from Eurotherm, which measure the % oxygen in a furnace. The carbon level is calculated from two inputs, the % O2 and temperature measured by the probe. An optional third input can accept a signal from a CO or H2 analyzer, thus providing a more precise carbon or dewpoint measurement.
In addition to carbon levels, the controller can be configured to measure % O2, log O2, dewpoint (°C or °F) and probe millivolts. A probe clean output forces compressed air through the probe at regular intervals to burn off soot. A sooting alarm will warn if carbon deposits
build up to give false readings. Health of the probe is measured by monitoring the time it takes the probe mV reading to recover from self-clean. Probe clean and CO/H2 compensation are enabled by digital inputs.
A range of plug-in modules provide control, alarm and retransmission options. Optional Modbus®, ASCII, or Profibus® communications are available.
ESO209 - This low cost version offers PID and two module slots plus Modbus® or ASCII communications.
ES0288 - This version is identical to ES0209, but with Profibus®-DPcommunications.
ES0278 - This version offers PID or valve control, two module slots, five relay outputs, Modbus® or Profibus® communications and an optional third slot for retransmission or CO compensation
应用于:
渗碳炉
吸热性气体装器
烧结炉
陶制品炉
特点:
氧化锆探头输入
温度输入
碳势,露点
探头清洁
探头诊断
运算和逻辑
  公开的通讯方式
关 键 词: 碳势控制器 2404 欧陆碳势控制器
公司名称: 广州博玮自动化设备有限公司
联 系 人: 曾莲莲
电  话: 020-32389052
手  机: 18002261356
地  址: 广州市黄埔区护林路104号骊丰大厦406室
邮  编: 510070
美国红狮Redlion模( CSPID)
美国红狮Redlion模(CSMSTRV2)
美国红狮Redlion模(CSTC8 / CSRTD6)
美国红狮Redlion模(CSSG)
美国红狮Redlion(CSINI8 / CSINV8)
美国红狮Redlion模(CSOUT)
美国Sixnet产品工业(通讯网关)
美国红狮Redlion模(CSMSTR LE/SX/GT)
美国Sixnet工业MO(VT-MODEM-5WW)
美国Sixnet产品工业(浪涌保护器)
美国Sixnet工业附件(工业电源)
美国Sixnet工业MO(VT-MODEM-4WW)
美国Sixnet产品工业(工业串口服务器)
美国Sixnet工业MO(VT-MODEM-3WW)
美国Sixnet工业MO(VT-MODEM-1WW)
美国红狮Redlion(G308K)
美国红狮Redlion (G306)
美国红狮Redlion(G306K)
美国红狮Redlion(G304K)
美国红狮Redlion(G315)
