欧陆EUROTHERM 多回路温度过程控制器900EPC
900EPC已经停止生产,现在用新型号2604/2704代替,咨询电话:020-32389052
The Eurotherm Model 900EPC Series of Controller/Programmers have moved to a Level 3 Obsolescence as of June, 2001. What does this mean?
- Orders from existing or new customers are no longer accepted.
- The 900EPC has been removed from any Product Catalogs and Price Lists.
- Adequate spare parts and components will be stocked at the Leesburg, Virginia, Repair facility for continuing warranty and long term non-warranty support of the 900EPC Series.
- The Eurotherm Repair facility will be able to provide service on the 900 EPC for a minimum of 3 years or more.
Is there a Replacement for the 900EPC? Yes!
There are two new products that are replacements for the 900 EPC. The model 2604 and 2704 three-loop controllers. The 2604 and the 2704 have the same cutout size as the 900EPC - 1/4 DIN. The 2604 has an LED display 2604 while the the 2704 has a graphical display. These instruments have a level of configurability, with math and logic functions and are supported by Eurotherm's new configuration software, iTools.
Actual Dimensions: 3.78H x 3.78W x 9.17D" (96H x 96W x 233Dmm) (with rear terminal cover) Panel depth (with rear terminal cover): 8.58" (218mm) |
The 900EPC series of controllers and programmer/controllers are high stability, high accuracy, communicating units designed to cope with a wide range of process needs and environments. The 16-bit 68070 microprocessor delivers the power of a PC; a number of ASICs significantly increase the I/O capability.
The 900EPC controllers are available in both single and dual-loop versions, as well as cascade and ratio versions. They feature modular hardware and software for control of simple or complex loops. Applications include: temperature, flow, level, density, viscosity, humidity, carbon, melt pump, gravimetric feed systems and other processes. |
1: 1/4 DIN size 2: Many advanced features! 3: 20 standard models for fixed control solutions 4: Accuracy=better than 0.1% 5: High speed input: up to 20 samples/sec. 6: PC communications + peer-to-peer 7: Optional 50 programs & 500 segments 8: Adjustable holdback available per program or per segment 9: 6 hardware and software configurable I/O expansion slots 10: Logic programming and software "user wiring" for custom applications 11: Real time clock for scheduled startup and shut down 12: Nema 4 (IP65) rating
理想适用于:
- 气氛炉
- 真空炉
- 半导体炉
- 蠕变和拉伸测试
- 高压灭菌锅
- 发酵罐和电抗器
- 挤塑熔化压力
特性:
- 3 个 PID 回路
- 超高精度过程输入
- 级联、比例、过调节
- 设定点编程
- 数学、逻辑和计时器
- 氧化锆和真空输入
- 熔化压力校准
- 整装锅炉控制
