产品名称: 富士驱动器
型  号:
    富士FRN-G11S系列、FRN-P11S系列、FRN-F1S系列、FRN-E1S系列、FRN-G1S系列变频器、富士断路器、热过载继电器、富士按钮开关、富士伺服系统伺服电机、富士接触器等高低压电器.
富士G11S系列变频器
FRN0.4G11S-4CX FRN0.75G11S-4CX
FRN1.5G11S-4CX FRN2.2G11S-4CX
FRN3.7G11S-4CX FRN5.5G11S-4CX
FRN7.5G11S-4CX FRN11G11S-4CX
FRN15G11S-4CX FRN18.5G11S-4CX
FRN22G11S-4CX FRN30G11S-4CX
FRN37G11S-4CX FRN45G11S-4CX
FRN55G11S-4CX FRN75G11S-4CX
FRN90G11S-4CX FRN110G11S-4CX
FRN132G11S-4CX FRN160G11S-4CX
FRN200G11S-4CX FRN220G11S-4CX
FRN280G11S-4CX FRN3150G11S-4CX
FRN355G11S-4CX FRN400G11S-4CX
FRN450G11S-4CX FRN500G11S-4CX
FRN630G11S-4CX
富士P11S系列变频器
FRN7.5P11S-4CX FRN11P11S-4CX
FRN15P11S-4CX FRN18.5P11S-4CX
FRN22P11S-4CX FRN30P11S-4CX
FRN37P11S-4CX FRN45P11S-4CX
FRN55P11S-4CX FRN75P11S-4CX
FRN90P11S-4CX FRN110P11S-4CX
FRN132P11S-4CX FRN160P11S-4CX
FRN200P11S-4CX FRN220P11S-4CX
FRN280P11S-4CX FRN315P11S-4CX
FRN355P11S-4CX FRN400P11S-4CX
FRN450P11S-4CX FRN500P11S-4CX
FRN630P11S-4CX FRN710P11S-4CX
富士电机电梯专用变频器
FRN5.5LMIS-4C FRN5.5LMIS-4C/PP
FRN5.5LMIS-4C/PS FRN5.5LMIS-4C/PR
FRN7.5LMIS-4C FRN7.5LMIS-4C/PP
FRN7.5LMIS-4C/PS FRN7.5LMIS-4C/PR
FRN11LMIS-4C FRN11LMIS-4C/PP
FRN11LMIS-4C/PS FRN11LMIS-4C/PR
FRN15LMIS-4C FRN15LMIS-4C/PP
FRN15LMIS-4C/PS FRN15LMIS-4C/PR
FRN18.5LMIS-4C FRN18.5LMIS-4C/PP
FRN18.5LMIS-4C/PS FRN18.5LMIS-4C/PR
FRN22LMIS-4C FRN22LMIS-4C/PP
FRN22LMIS-4C/PS FRN22LMIS-4C/PR
FRN30LMIS-4C FRN30LMIS-4C/PP
FRN30LMIS-4C/PS FRN30LMIS-4C/PR
FRN37LMIS-4C FRN37LMIS-4C/PP
FRN37LMIS-4C/PS FRN37LMIS-4C/PR
FRN45LMIS-4C FRN45LMIS-4C/PP
FRN45LMIS-4C/PS FRN45LMIS-4C/PR
富士新型变频器G1S系列:
FRN0.4G1S-4C FRN0.75G1S-4C
FRN1.5G1S-4C FRN2.2G1S-4C
FRN3.7G1S-4C FRN5.5G1S-4C
FRN7.5G1S-4C FRN11G1S-4C
FRN15G1S-4C FRN18.5G1S-4C
FRN22G1S-4C FRN30G1S-4C
FRN37G1S-4C FRN45G1S-4C
FRN55G1S-4C FRN75G1S-4C
FRN90G1S-4C FRN110G1S-4C
FRN132G1S-4C FRN160G1S-4C
FRN200G1S-4C FRN220G1S-4C
富士E1S系列小型变频器
FRN0.4E1S-4C FRN0.75E1S-4C
FRN1.5E1S-4C FRN2.2E1S-4C
FRN3.7E1S-4C FRN5.5E1S-4C
FRN7.5E1S-4C FRN11E1S-4C
FRN15E1S-4C FRN0.1E1S-7C
FRN0.2E1S-7C FRN0.4E1S-7C
FRN0.75E1S-7C FRN1.5E1S-7C
FRN2.2E1S-7C FRN0.1E1S-2J
FRN0.2E1S-2J FRN0.4E1S-2J
FRN0.75E1S-2J FRN1.5E1S-2J
FRN2.2E1S-2J FRN3.7E1S-2J
FRN5.5E1S-2J FRN7.5E1S-2J
FRN11E1S-2J FRN15E1S-2J
   富士faldic-α伺服
   控制功能可以从以下3种中选择。
◆ rys-v类型:脉冲列/速度控制型,根据上位控制器的脉冲指令、模拟量速度指令运行。
◆ rys-l类型:内藏直线定位功能滚珠螺钉、有槽导轨、小齿轮等的结构可构成直线定位系统。
◆ rys-r类型:旋转分度功能内藏型可构筑atc、工具仓库、移动机器等分度系统。
    伺服电机
    伺服电机可从2种类型中选择。
◆ gys系列:低惯性类型, 和老型号(grh系列)相比法兰尺寸减小到1/2、保持大能量,但可以放到原来放不下的狭小空隙中
◆ gyc系列:中惯性类型, 和老型号(grh系列)相比厚度尺寸减小到1/2、伺服电机后部可以完全放到机械内部。
    编程软件
◆ 备有可直观操作的伺服系统开发软件(cd)
◆ 参数编辑上不仅可进行参数改写、复制,还可自动根据机械规格选定参数
◆ 监控功能可进行速度、位置、转矩波形等的监控(图形显示)
◆ 具有故障诊断功能,报警发生时的原因推测,可在[不能运行]时进行诊断,可使用照片、图解、文字进行故障原因判断。
    富士faldic-α系列在4个[f]的概念上,提高基本性能,备有高效的编程软件,备有现场即时进行机械自整定的功能。可实现设定时间的短缩、机械性能的向上。
其他特点
◆ fine
  具有1秒钟600次的正反转响应(频率应答600hz)、定位控制时间1ms的控制性能。而且和低惯性伺  服电机(gys系列)组合,可在高容量、高转矩运转的机械上使用。
◆ friendly
  用编程软件可进行伺服电机的容量选定、试运行、检修维护、故障诊断等综合支持。 标准装备控制  电源输入用端子,易于维护,在切断动力电源状态下也可进行维护。
◆ flexible
  伺服电机带有inc/abs共用的节省接线的16bit串形编码器。 编码器的接线有电源线2条、信号线2条,共4条线。 而且和伺服放大器、电机组合后,在标准(同一容量)组合以
外的电机也可不改变设定运行。上位接口包括[di/do]、[rs485],以及本公司特有的sx总线、t链。
◆ facility
    富士W系列伺服简介                                                         富士W系列伺服继FALDIC-α、β之后,FALDIC系列诞生了新机种。FALDIC系列的进化是为了因应所有市场的要求。新诞生的『FALDIC-W』标准搭载了17位元的编码器,除了伺服系统的标准功能中纳入了减振控制功能外,还可以选择马达的额定运转速度,可依照不同的用途来选择适合的FALDIC系列。
改进方面:
1、标准配备131072脉冲的高分辨率编码器。
2、搭载“减振控制功能”以有效地对策机械手臂前端的振动。
3、标准配备RS-485 2个通信接口。
其他特点:
1、输入控制电源,标准配备主电源和控制电源输入。传感器的位置在断电等情况下很方便。紧急情况下,主电源断电的系统中,不需要进行原点复位。
2、调试简单,利用伺服放大器进行机械的自动往复运行,就能实现简单方便的自整定。在没有安装定位控制器等的上位装置的情况下,也能实现机械与伺服电机最理想的自整定。
3、伺服分析器功能,利用我公司的调试软件对机械固有的「共振频率」等进行分析,可以有效利用「减振控制功能」、「陷波滤波器」等功能。
4、试运行功能,不仅支持单方向的JOG运行,也支持连续往复运行。在没有安装上位控制装置的情况下,同样能够简单测试出与实际运行相接近的实际转矩。
5、 结构紧凑。
6、IP67(伺服电机)伺服电机对应IP67标准。即使在水、尘埃的环境下也能使用(不包括GYS电机的轴端和连接器部分。不包括GYG电机的轴端)。
7、完全符合「CE记号」「UL/cUL」的标准,全球通用的伺服。
    富士变频器全称为“富士交流变频调速器”,主要用于三相异步交流电机,用于控制和调节电机速度。
    当电机的工作电流频率低于50Hz的时候,会节省电能,因此变频器是国家号召提倡推广的节能产品之一。
    随着节能的普及和工业自动化的推广,变频器的使用越来越多,每年在中国有上百亿的销售额。
    富士变频器是世界知名的变频器之一,由富士电机株式会社生产,在世界各地占有率比较高。
    富士变频器来到中国有20多年的历史,现在市场上主要使用的有以下系列: 1.FRENIC5000VG7S系列变频器
2、FRENIC5000G11S系列低噪声高性能多功能变频器
3、FRENIC5000P11S系列低噪声·风机·泵用变频器
4、FRENIC-MEGA G1S系列(富士电机最新推出)
5、FRENIC-VP F1S系列低噪声·风机·泵用变频器(富士电机最新推出)
6、C1S系列
7、E1S系列
富士伺服电机 富士变频器 富士驱动器 FUJI伺服电机 FUJI变频器 FUJI驱动器
关 键 词: 富士驱动器 富士伺服电机 富士变频器
公司名称: 宁波贝塔斯自动化科技有限公司
联 系 人: 张志展
电  话: 0574-66835923
手  机: 13362457282
地  址: 宁波市北仑区凤洋二路711号
邮  编: 315800
三菱驱动器
SOR压力开关
ASCO双电源转换开关
ASCO防爆电磁阀
