波士电子:RS-232/RS-485正宗专业厂家 TEL027-62425625
BOSI electronics:RS-232/RS-485 expert English 中文
BOSI RS-232 optical-isolators
- Currently,only BOSI can realize more than 3-wire RS-232 optical isolation
- in DB-9/DB-9 socket-size in the world!
- Allmost no RS-232 voltage drop、30m distance guarentee!
- Higer rate、smaller size、smarter appearence!
- No power supply absolutely!
Click the MODEL name ,the datasheet will be opened (.pdf)
| Model | Function | Feature | Price |
| BS232-9 | RS-232 optical isolator | DB-9/DB-9 size | $49 |
| BS232-25 | RS-232 optical isolator | DB-25/DB-25 size | $49 |
| BS232B-9 | RS-232 optical isolator | DB-9/DB-9 size、more hand-shake signal | $72 |
| BS232C-9 | RS-232 optical isolator | DB-9/DB-9 size、all nine RS-232 signals | $98 |
| BS232C-25 | RS-232 optical isolator | DB-25/DB-25 size、all RS-232 signals | $72 |
| Y232A2 | RS-232 optical-isolated extender | DB-9/DB-9 size | $49/pair |
| Y232B9 | RS-232 optical-isolated extender | all nine RS-232 signals | $100/pair |
BS232 series products data sheet Y232A2 and Y232B9 data sheet
波士RS-232 光电隔离器——速率更快、体积更小、外形更酷!(均无源)最高9600bps
DB-9 |
1 |
2 |
3 |
4 |
5 |
6 |
7 |
8 |
9 |
DB-25 |
8 |
3 |
2 |
20 |
7 |
6 |
4 |
5 |
22 |
定义 |
DCD |
RXD |
TXD |
DTR |
GND |
DSR |
RTS |
CTS |
RI |
