EPXN压力传感器The EPXN is a high performance small pressure sensor using silicon chip for clean media (non corrosive).With it's recessed port, it is best recommended for static applications or low frequency. Available with 10-32UNForM5 thread, EPXN is available with a cable or integral connector. Offered in pressure ranges from 5 to 150 psi (0.3 to 10 bar), vented and absolute pressure.Various compensated temperature ranges are available from -40°C up to 90°C. The sensor is offered with an amplified or unamplified output.
所属品牌: Entran
输出: 50-75 mV 或 5 Vdc
量程: 0-5~150(Psi)
封装:不锈钢外壳封装
工作温度范围:-40℃~120℃
精确度:0.1% FSO
供电电源:5~30V(视输出而定)
特点:长期稳定性好,凹膜片,螺纹接口
类型:表压、绝压
电气连接:电缆
典型应用: 实验机、飞行器、宇航,干式静态压力长期稳定性能监测
资料下载:
http://www.sensorway.cn/sensors/20.html
