EPXM压力传感器:The EPXM is a subminiature pressure sensor, specifically designed for Dynamic and High Frequency measurements with resonant frequency up to 1.7 MHz. Available with many various housings, EPIH is one of the smallest pressure sensors in the world. The EPIH is offered in pressure ranges from 0-5 to 300 psi (0-0.35 through 20bar).Variouscompensated temperature ranges are available from -40°C up to 80°C.
Suitable for dry gas and some fluids with Parylene or RTV protection (options). Nonstandard excitation, compensated temperatures are available as options.
所属品牌: Entran
输出: 9mV 或 5V
量程: 0-150,200,300,500,1000,1500,2000,3000,5000(PSI)
封装:-
工作温度范围: -40℃~125℃
精确度:0.1% FSO
供电电源: 视输入而定
特点:小螺纹、高精度、放大输出
类型:表压、绝压
电气连接:电缆
典型应用: 航天、试验设备、发动机
资料下载:
http://www.sensorway.cn/sensors/185.html
