EPE压力传感器:The EPE is a subminiature pressure sensor, specifically designed for Dynamic and High Frequency measurements with resonant frequency up to 1.7 MHz. Available with many various housings, EPIH is one of the smallest pressure sensors in the world. The EPIH is offered in pressure ranges from 0-5 to 300 psi (0-0.35 through 20bar).Variouscompensated temperature ranges are available from -40°C up to 80°C.
Suitable for dry gas and some fluids with Parylene or RTV protection (options). Nonstandard excitation, compensated temperatures are available as options.
所属品牌: Entran
输出: 120 mV ~ 400 mV
量程: 0-2, 5(PSI)
封装:-
工作温度范围:-40℃~120℃
精确度:0.75-1.5% FS
供电电源:10VDC(标准)
特点:低压,高灵敏度,超小型
类型:表压、绝压
电气连接: 电缆
典型应用: 风洞、火箭测试、爆炸测试、试验过程监测
资料下载:
http://www.sensorway.cn/sensors/184.html
