EGAS3加速度计:The Model EGAXT3 miniature triaxial accelerometers combine a damping ratio of 0.7 (Nominal) with built-in overrange stops that are set to protect the unit against 10,000g shocks. This is ideal for applications which may experience rough handling or in situations where the accelerometer must survive a high initial overload in order to make a low g measurement. These units feature a Wheatsone Bridge output with compensated temperature range of 20 to 80°C.
所属品牌: Entran
输出: ±100mV
量程: ±5 ,±10 ,±25 ,±50 ,±100 ,±250 ,±500 ,±1000 ,±2500g
封装:阳极氧化铝
工作温度范围:-40℃ ~ 120℃
精确度:1% FSO
供电电源:15 VDC
特点:小型加强型三轴加速计, 各个轴可选有不同量程,有铠包电线,内置过载保护和粘滞阻尼
类型:粘合剂,螺钉安装
电气连接:电缆连接
典型应用: 振动监控,惯性导航,运动控制,碰撞测试
资料下载:
http://www.sensorway.cn/sensors/112.html
