3028加速度传感器:The Model 3028 is a piezoresistive silicon accelerometer packaged on a ceramic substrate with a metal bracket which can be used to bolt the sensor to the mounting location. The accelerometer consists of a micro machined silicon mass suspended by multiple beams from a silicon frame. Piezoresistors located in the beams change their resistance as the motion of the suspended mass changes the strain in the beams. Silicon caps on the top and bottom of the device are added to provide over-range stops. This design provides for a very low profile, high shock resistance, durability and built-in damping over a wide usable bandwidth. For an accelerometer with an adhesive mount design, see the Model 3022. Please refer to the Models 3052 and 3058 for accelerometers with integral temperature compensation.
所属品牌: ICSensors
输出: 10~0.4 mV/g
量程: ±2,±5 ,±10 ,±20 ,±50 ,±100 ,±200g
封装:法兰安装
工作温度范围:-40℃ ~ 125℃
精确度:0.5% FSO(非线性)
供电电源:5 VDC
特点:PC板安装,低成本,mv输出,螺钉支架安装
类型:单轴加速度计
电气连接:板载式
典型应用: 振动、冲击测试,模态分析,运动控制,碰撞实验,运输监测
资料下载:
http://www.sensorway.cn/sensors/94.html
