3255加速度传感器:The Model 3255A is a signal conditioned board mountable MEMS accelerometer available in ±25g to ±500g ranges. The package can be mounted in one of two orientations, allowing the measurement axis to be either parallel or perpendicular to the mounting surface without the use of costly brackets. The accelerometer incorporates integral temperature compensation from -40°C to +100°C and offers a flat frequency response from DC to 1500Hz.所属品牌: ICSensors
输出: 0.5~4.5VDC (80~4 mV/g)
量程: ±25,±50 ,±100 ,±250 ,±500g
封装:SMD
工作温度范围: -40℃ ~ 125℃温度补偿
精确度:0.2% FSO(非线性)
供电电源:5 VDC
特点:PC板安装,允许测量轴与安装平面平行或垂直安装 而无需支架,自检功能,报警输出,放大输出,温度补偿
类型:单轴加速度计
电气连接: 板载式
典型应用: 碰撞测试,振动监测,航空测试 ,运输
资料下载:
http://www.sensorway.cn/sensors/93.html
